Change the ip segment in "Failover ip state" could causes any problem?
griffith2009
I have two firewall configured in fail over, in production, i need to change ip segment of ip state.
Model: PIX-515E
Version: pix7.2(4)
Conf:
interface Ethernet5
description STATE Failover Interface
failover
failover polltime unit msec 200 holdtime 1
failover replication http
failover link state Ethernet5
failover interface ip state 1.1.1.1 255.255.255.0 standby 1.1.1.2
if i execute the command
failover interface ip state 1.1.2.1 255.255.255.0 standby 1.1.2.2
i will have any problem ?
Jon Marshall
Maria
Depends what you mean by problem. Bear in mind that you will have to update the standby firewall as well with it's new IP ie. 1.1.2.2.
It will be fine but it should definitely be done out of production hours ie. a scheduled downtime.
Jon
