Change the source IP on NAT
brendanhoran
I need to change the source IP of a packet for one of my NAT's
I currently have an Cisco 1812.
I have an PPPoE connection as Dialer 0.
I have another VLAN that is connected to an Netscreen SSG5 VPN gateway via another Cisco switch.
I have a vlan trunk between the switch and the 1812.
What I would like to achive is the following :-
For any traffic going to the following three ranges make it apear as if it was coming from the VLAN50 address
Hear is the thee ranges :-
access-list 150 permit ip 192.168.0.0 0.0.255.255 any
access-list 150 permit ip 172.16.0.0 0.0.240.255 any
access-list 150 permit ip 10.0.0.0 0.0.0.255 any
Hear is where I need to send it :-
ip route 10.0.0.0 255.0.0.0 10.27.30.225
ip route 172.16.0.0 255.240.0.0 10.27.30.225
ip route 192.168.0.0 255.255.0.0 10.27.30.225
I have defined a VLAN with an ip address of 10.27.30.226
interface Vlan50
ip address 10.27.30.226 255.255.255.248
ip virtual-reassembly
I can ping my netscreen on 10.27.30.255 fine from the Cisco 1812. But any other PC fails, as for some reasion the traffic has a source of my Dialer 0 interface.
How can I write a nat to change the source just for the tree destitnations ?
7 Replies 7
Josh Sprang
Looks like there may be an ACL or routing problem. Can u post your config? And a copy of show ip route from the 1812?
Also what is the subnet of the pcs and what is the default gateway of the pcs?
Config attached.
#sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, + - replicated route
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
S*    0.0.0.0/0 is directly connected, Dialer0
      1.0.0.0/32 is subnetted, 1 subnets
C        xxx.xxx.xxx.xxx is directly connected, Dialer0
      10.0.0.0/8 is variably subnetted, 3 subnets, 3 masks
S        10.0.0.0/8 [1/0] via 10.27.30.225
C        10.27.30.224/29 is directly connected, Vlan50
L        10.27.30.226/32 is directly connected, Vlan50
      xxx.0.0.0/32 is subnetted, 1 subnets
C        xxx.xxx.xx.xxx is directly connected, Dialer0
S     172.16.0.0/12 [1/0] via 10.27.30.225
S     192.168.0.0/16 [1/0] via 10.27.30.225
      192.168.0.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.0.0/24 is directly connected, Vlan10
L        192.168.0.254/32 is directly connected, Vlan10
PC subnet is 192.168.0.x 255.255.255.0
Default g/w is 192.168.0.254
Try putting ip nat outside under interface VLAN 50.
interface Vlan50
ip nat outside
zone-member security LAN
No help
Still can not ping an IP address from a machine on my network to the VPN
RESOLVED!
I set Vlan 50 and Vlan 10 to have "ip nat enable"
I removed "ip nat outside" on vlan 50
I added the following to translate the source
ip nat source static 192.168.0.2 10.27.30.226
Now it all works.
Only from 192.168.0.2 as expected.
Not sure how I can translate for any address.
Can u ping the netscreen trust interface from a pc?
Sent via DroidX2 on Verizon Wireless™
Yes I can and any IP address in VPN. Of course only from 192.168.0.2  but that sok with me right now.
