Change Uplink By community Tag
HI Dears Customer Announce to me Prefix X.X.X.X/24 if without tag announce upnllink 1 if customer used tag 200:200
in route-map that assign bgp uplink 1 deny tag 200:200 in ASR add
ip bgp-community new-format
show ip bgp X.X.X.X/24
BGP routing table entry for 87.107.111.0/24, version 74678
Paths: (1 available, best #1, table default)
Advertised to update-groups:
2 9 13
Refresh Epoch 1
208555 208555 51026, (received & used)
172.18.22.26 from 172.18.22.26 (172.19.19.1)
Origin IGP, localpref 100, valid, external, best
Community: 13107400
rx pathid: 0, tx pathid: 0x0
Updated on Oct 22 2024 16:57:45 UTC
BGP routing table information for VRF default, address family IPv4 Unicast
BGP routing table entry for 87.107.111.0/24, version 2092
Paths: (2 available, best #1)
Flags: (0x8000001a) (high32 00000000) on xmit-list, is in urib, is best urib rou
te, is in HW
Advertised path-id 1
Path type: internal, path is valid, is best path, no labeled nexthop, in rib
AS-Path: 208555 208555 51026 , path sourced external to AS
172.18.14.254 (metric 0) from 172.18.14.254 (185.217.6.66)
Origin IGP, MED 0, localpref 800, weight 0
Community: 200:200
Path type: internal, path is valid, received only, no labeled nexthop, is extd
Origin IGP, MED 0, localpref 100, weight 0
Community: 200:200
and this community see but in nexus 9K announce to uplink1 and uplink 2
10 Replies 10
balaji.bandi
what are you trying to achieve with the TAG, does your provide accept that do something with that ?
if not then use normal network announcements.
BB
On nexus 9K define route-map on uplink1 and
route-map uplink-1 deny 1
macth community 200:200
end of rule
But
Donnot work also announe on uplink-1 prefix X.X.X.X/24 by community tag 200:200
Not sure any Limitation on nexus need to check the documentation : generally i do as below not send community
May be try - check before you apply the commands.
ip prefix-list MYLIST permit X.X.X.X/24
route-map MYLIST permit 10
match ip addr prefix MYLIST
set community no-export
route-map MYLIST permit 20
router bgp BBBB
neigh y.y.y.y send-community
neigh y.y.y.y route-map MYLIST out
BB
Donnot used deny rules if community 200:200 set bgp community no-export-only and used accept rules ????
Used this
route-map respina, permit, sequence 6
Match clauses:
community (community-list filter): 200:200
Set clauses:
community no-export
By uplink see my prefix by community 200:200
my nexus version is
NXOS image file is: bootflash:///nxos64-cs.10.3.5.M.bin
not that i have tested nexus need to test in Lab, may be over weekend let me test if i get chance.
BB
Thanks i am waiting
I have made typo that should be deny and tested and it works.
On the nexus :
ip prefix-list MYLIST seq 5 permit 20.20.20.0/24
route-map MYLIST deny 10
match ip address prefix-list MYLIST
router bgp 100
address-family ipv4 unicast
neighbor 10.10.5.1
remote-as 300
update-source Ethernet1/2
send-community
send-community extended
neighbor 10.10.6.1
remote-as 400
update-source Ethernet1/3
neighbor 10.10.10.2
remote-as 200
update-source Ethernet1/1
This works for me i can not see the routes of 20.20.20.0/24 on the neighbor 10.10.5.1
BB
Hello
TBH not so sure what your trying to achieve, however it seem your trying so send a prefix towards a bgp peer and for that peer then not to re-advertise onwards based on community attribute of NO-EXPORT if so,  then that receiving rtr MUST also send community upstream otherwise the attribute will be stripped from the prefix and advertised normally
example
ASR
router bgp xxx
neighbour <9K>  send-community
9k
router bgp xxx
neighbour <uplink1>  send-community
neighbour <uplink2>  send-community
Kind Regards
Paul
Enable send community in  address-family but my problem is community- Not change or prefix disacrd
