Changing AD for external EIGRP routes.
Hello guys.
I have two routers running both EIGRP and OSPF, i would like the EIGRP routes to be installed into the routing table rather than OSPF, but my guess is that the external EIGRP routes have a larger Administrative Distance than the OSPF routes.
How do i change the Administrative distance of the external EIGRP routes?  am redistributing static routes.
regards.
luckymike33
Under the EIGRP process you use the distance command, as follows:
 i.e. R1(config)# router eigrp 100
      R1 (config-router)# distance eigrp [internal AD] [external AD]
and just reduce the external AD, to below 110. But be careful, these values are there for a reason.
Very best wishes
Mike
