Customers Cisco 1941 Router
Thomas Summers
I ma working with a customer to get internet traffic through a Cisco 1941 router.  I have not worked with these routers before.  below is the current config for the router. What am I missing.  I can ping 8.8.8.8 (Google) from the router, but not from a pc connect to gig0/0.
TVC_TOS#sh run
Building configuration...
Current configuration : 2298 bytes
! Last configuration change at 13:56:19 UTC Mon Apr 14 2014 by tXXXXXXXXXXX
version 15.2
service password-encryption
hostname TVC_TOS
boot-start-marker
boot-end-marker
enable password 7 XXXXXXXXXXX
no aaa new-model
ip cef
ip domain name tvcconnect.net
ip name-server 64.72.64.10
ip name-server 8.8.8.8
no ipv6 cef
license udi pid CISCO1941/K9 sn FGL172021GD
username cXXXX privilege 15 password 7 XXXXXXXXXXX
username tXXXXXXXX privilege 15 password 7 XXXXXXXXXXXXX
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description To TOS Firewall
 ip address 192.168.110.130 255.255.255.0
 ip nat inside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/0/0
 description TVC to TOS Interfeace
 ip address 67.231.65.98 255.255.255.252
 ip nat outside
 rate-limit output 10000000 1875000 38750000 conform-action transmit exceed-action drop
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat pool internet 67.231.65.98 67.231.65.98 prefix-length 30
ip nat source list 20 pool internet overload
ip route 0.0.0.0 0.0.0.0 67.231.65.97
access-list 1 permit 192.168.110.0 0.0.0.255
access-list 10 permit any
access-list 20 permit 192.168.110.0 0.0.0.255
access-list 100 permit tcp any any eq www
access-list 100 permit tcp any any eq 443
access-list 100 permit tcp any any eq ftp
access-list 100 permit tcp any any eq ftp-data
access-list 100 permit tcp any any eq telnet
access-list 100 permit udp any any eq domain
access-list 100 permit udp any eq domain any
access-list 100 permit tcp any eq domain any
access-list 100 permit tcp any any eq domain
access-list 100 permit udp any any eq echo
control-plane
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 access-class 10 in
 login
 transport input all
scheduler allocate 20000 1000
ntp server 67.231.65.97
end
mfurnival
Level 4
Level 4
On the router do:
#term mon
#debug ip nat trans
Then from your LAN PC ping 8.8.8.8.
This should show if the packet is actually getting to the router and whether the NAT configuration is working correctly.
mfurnival
Level 4
Level 4
On the router do:
#term mon
#debug ip nat trans
