Changing BGP router-id
johnlloyd_13
Level 9
Level 9
hi,
i'll be changing an ISP/BGP peer. my question is, do i negate first the old bgp router-id or just directly configure/apply the new router-id?
do i need to do a "clear ip bgp" to establish the new ISP/BGP peer?
router bgp 65123
 neighbor 63.21.16.4 shutdown   <<< OLD ISP/BGP PEER
 no bgp router-id 63.21.16.4
 bgp router-id 63.22.11.18
when you change the router-id the bgp is down and then UP again and use new router-id
MHM
johnlloyd_13
Level 9
Level 9
hi,
you just added a new BGP router id.
my question is, how do you change the existing router id to a new one using a new BGP peer?
do you overwrite it or negate first the current config with a "no router-id x.x.x.x"?
will it bounce or do i need to issue a "clear ip bgp *"?
To clear point here
1- the all bgp have one router-id' there us no router-id per peer
2- when you add new router-id the old one automatically remove' and bgp use new one
MHM
