sdwan vs mpls or dedicated lines
abdul.qadir5001
From the business aspect, why would we recommend a client to use sdwan vs mpls or dedicated lines
Joseph W. Doherty
Answer would depend on business requirements and business funding capacity.
balaji.bandi
Sure agree with @Joseph W. Doherty  - How much you can spend, and what is the use case to have dedicated lines. when you able to achieve same using MPLS or over internet (depends on requirement).
some use case i worked., to save the cost use combination dedicated and MPLS, MPLS and Internet
BB
