Changing route from one location to another
scotlaclair
I have two sites A and B connected by T1 line. Site A has another T1 line connecting A-C and Site B has another T1 line connecting B-C. I want to eliminate one of the T1 lines B-C so I need to route the B-C connection from B-A-C instead using the T1 line that connects B-A and then A-C. I cannot make it work. From site B I can ping all the addresses at A that I need to access and at site A I can ping all the addresses at sites B and C, but from B to C I can't connect.
7 Replies 7
mhussein
Level 4
Level 4
Unless I am missing something, it should be straightforward. Check the routing tables on all sites. Remove stale routes, and add static routes if you have to:
RouterB:
ip route
RouterC:
ip route
Mustafa
hi, have you done it or it is still pending. As I was doing the same changes so that we could easily manage www.techtheeta.com/best-tablets-with-stylus-for-note-taking/ without facing any issues. As I tried my best and applied all the knowledge which I have but all in vain. Then one of my friend suggest me to hire an expert related to this job from any freelancing market place. When I hired a person from fiverr he did it in just a few minutes.
it depend one what routing protocol you run between sites.
what is routing protocol you run ?
Garry Cross
If static routing is in use.
On B
You would have a route like this.
ip route networksC maskC nexthopC
You would need to delete this route.Then add this.
ip route networkC maskC nexthopA
On C you would do similar for NetworkB
Remove route
ip route NetworkB MaskB nexthopC
Add route
ip route NetworkB maskB nexthopA
Hello
Post a topology diagram so we can better understand your requiement
Kind Regards
Paul
The original post was from 2005. I do not know why it was resurrected but the person who did so explains that the problem has been solved (after giving what appears to be a plug for some product whose relationship to network is not clear to me). I suggest that this is not worth more of our time - let it go.
Rick
Hello Richard
Thanks for that, I didnt realise the timestamp (17 years ago!)
Kind Regards
Paul
