Channel group issue
Jim Yorke
Hello all!
I ran into an issue when assigning a channel group to an interface on my C9372PX core switches running EIGRP.  I created a port channel on both cores and assigned the channel-group 45 to interface Ethernet1/45 with no issues.  When attempting to assign the channel-group 45 to Ethernet1/45 on my second core the command bandwidth inherit 1 showed up and have no idea why it appeared on one switch and not the other.
Ok @Jim Yorke
please try this:
no channel-group 45
no shut
follow:
no bandwidth
switchport mode trunk
switchport trunk allowed vlan 45-46,150,200
spanning-tree port type normal
channel-group 45
Best regards
10 Replies 10
M02@rt37
Hello @Jim Yorke
Could you please confirm whether ip routeur eigrp 'asn' command is configured on the Po45 interface on both core switches?
Best regards
No it is not.  Here is the config from both cores:
Core 1
description New Revenue Switch
shutdown
bandwidth inherit 1
channel-group 45
interface port-channel45
description vPC45 Revenue
vpc 45
Core 2
channel-group 45
vpc 45
Could it have been there before configuring the port channel? Can you remove it and see if it causes any issues. I assume if both devices are the same maybe a different/updated IOS could have added that command.
-David
Same IOS on both cores.  The command appeared after I added the channel-group 45 command.  Attempted to use the no bandwidth inherit 1 command and it gave me an error.
This is the result of using the no command to remove the statement:
% Invalid command at '^' marker.
Annex-Core-1(config-if)# no bandwidth inherit 1
Thanks @Jim Yorke
the interface on CORE-01 had manual bandwidth override before becoming part of Po45 ?
Best regards
Pre channel-group 45 command:
shutdown
Ok @Jim Yorke
please try this:
no channel-group 45
no shut
follow:
no bandwidth
channel-group 45
Best regards
M02@rt37, worked like a charm!  Thank you so very much for your help.  Any idea why this one interface and none of the others would add that inherit bandwidth 1 when assigning the port channel?
channel-group 45
Great @Jim Yorke, you're so welcome.
I suspect the no shut command help us also ...
The best way in this case is too reconfigure from scrach the interface ...
Best regards
