Check IP/packets in "Default" class
paulwoodsy
I'm wanting to clean up the default class-map. At the moment the key apps are not grouped into a manual class-map & fall under the "default" class.
It is concerning that during congestion key apps have to scrap for bandwidth. I'm looking to distinguish key applications & move them into existing class-maps.
My proposal is to match on destination IP addresses.
The proposed router config looks like this:-
ip access-list extended CAT1_APPS_ACL
remark *** Category 1 Applications -  Destination IP's ***
permit ip any host 1.1.1.1
permit ip host 1.1.1.1 any
class-map match-any EXISTING_CLASS-MAP
match access-group CAT1_APPS_ACL
policy-map EXISTING_OUT_POLICY
class EXISTING_CLASS-MAP
  set dscp cs3
int ***
service-policy output EXISTING_OUT_POLICY
Other than creating a span session is there a way to view relevant IP details within the default class? I need to verify/create a baseline of what is currently visible in the default class,
then post implementation check again to ensure they've been migrated to the EXISTING_CLASS-MAP.
To add, we dont have netflow either.
Any thoughts are appreciated.
Edison Ortiz
There isn't a way to detail what falls under the default class-map.
Your idea should work.
Edison
Thanks for your reply Edison.
I have tried this today & can see matches under the CAT1_APPS_ACL & I also see pkts incrementing under my class-map too. (sh policy-map int *** output class EXISTING_CLASS_MAP)
This is evidence enough that these key apps no longer fall in the default class
Great, thanks for the post back.
