check open ports on router/switch
jrramoliya
How can we check for open ports on router/switch?
7 Replies 7
Leo Laohoo
What "ports"?  Physical or Logical ports?
tcp/udp ports, suppose my router has ssh enable. how can see from "show command " my router is listening  on 22 port?
By default all ports (TCP/UDP) are open because there is no ACL in place.
thanks for your quick replay,
can you tell me the exact command to check open ports, i used bellow command , but that command is not supported . my router using 15.2(4)S2 IOS.
#show control-plane host open-ports
walter baziuk
Level 5
Level 5
i use this tcl script on all my devices
simply rename  the file to end in .TCL
download the file into flash:ipInterfaces.tcl
configure alias exec ipconfig tclsh flash:ipInterfaces.tcl
invoke with ipconfig [active|configured|address]
KerberosVE
You can use this command:
Thanks man.. i was trying to search for this since long.
