Service on port 10000 on 3945 ISR
PACC
Hi all,
So a port scan on our 3945 ISR shows a service listening on port 10000.
I ran show control-plane host open-ports but there was nothing on port 10000.
Can anyone advise what this might be or how I can find what it is?
cheers
sk
marce1000
 - Unclear whether this is relevant  :
             https://www.tcp-udp-ports.com/port-10000.htm
 M.
Thanks for the reply. Can you advise what on the router is running that is listening on thisport and whether it is needed?
in addition to the other post, I found the information in the link below. That said, if you don't need it, block it (with an access list)...
https://searchstorage.techtarget.com/definition/NDMP
