01-20-2011 05:32 PM - edited 03-04-2019 11:09 AM
I need to upgrade IOS on my 6509 MSFC2. Below is the software version I have on the Sup2 and msfc2. The reason I need to upgrade the msfc2 IOS is that I need to implement ip sla/object tracking and it is not supported by the current version of IOS on msfc2. How do I select the new IOS that I should upgrade the msfc2, in order to achieve object tracking...I see a long list of IOS in the software download section of 6509 msfc2, but not sure which one to choose..
WS-X6K-SUP2-2GE: Sw : 8.6(4)
WS-F6K-MSFC2: Sw : 12.1(19)E1
Thank you.
Solved! Go to Solution.
01-21-2011 12:38 AM
You can go with s222-adventerprisek9_wan-mz.122-18.SXF17a.bin, or you can find the best suited IOS for your configurations from cisco feature navigator.
01-21-2011 04:08 AM
Hello Network User,
your device is running in Hybrid Mode:
catOS on supervisor2
an IOS image on MSFC2
the question is that you may need to move to more current Native IOS like the image suggested by Yasif.
to check what you need you can use the feature navigator
search by feature
type IP SLA
take IP SLA ICMP Echo operation
described here:
http://www.cisco.com/en/US/docs/ios/ipsla/configuration/guide/sla_icmp_echo.html
according to Cisco FN a possible image to be installed on MSFC2 ( ios for hybrid mode)
the conversion procedure from Hybrid to Native mode for supervisor2 is :
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/hardware/Config_Notes/78_16872.html
if you need to convert follow the above procedure carefully.
then you can use a native IOS image.
Edit:
a link to reliable static routing with object tracking that might be useful
http://www.cisco.com/en/US/docs/ios/12_3/12_3x/12_3xe/feature/guide/dbackupx.html
in older IOS images the rtr object could be used
Hope to help
Giuseppe
01-21-2011 12:38 AM
01-21-2011 04:08 AM
Hello Network User,
search by feature
type IP SLA
described here:
Edit:
Hope to help
Giuseppe
01-22-2011 01:50 PM
Thanks Giuseppe and Yasif!
I will try to implement rtr object with my current IOS. If needed I will upgrade it to appropriate IOS..
Thanks!!
01-24-2011 01:54 PM
Hello Giuseppe,
I tried to implement the rtr object on my msfc2 IOS version. I could use all the commands except the "track" command to track the object. Do you kow if there is any other command which can be used on my version on IOS for tracking the object??
Thank you.
