CHUNKINVALIDHDR error with a cisco 871
raul.wamba
Hi everybody,
i have a cisco 871 configured with a VPN, and it suddenly started writing out through console this message:
"%SYS-2-CHUNKINVALIDHDR: Invalid chunk header type 1 for chunk 83876948, data 838778AC -Process= "IP Input", ipl= 3, pid= 72,  -Traceback= 0x8084F720 0x80037078 0x8034D438 0x8170FA3C 0x8170D6AC 0x8170D978 0x816E6BD0 0x8190F7CC 0x8190468C 0x819048B8 0x8190FE74 0x80C13514 0x80C13DB8 0x80C15578 0x80C1560C 0x80C2DA5C".
I´ve found in google some information about chunk errors, but i think that´s not my case:
Symptoms: Sometimes WebVPN login page may not come up when a client  browser connects to the gateway. Sometimes, login page may come up, but  after entering the login credentials portal page does not come up. The  following syslog messages are seen.
1) We are able to enter the webvpn login page, but after entering the  username and password, the page returns the error message "Internal  Error" and does not let us login. Also, the traceback below is seen.
May 10 06:15:19.183 PDT: %SYS-2-CHUNKINVALIDHDR: Invalid chunk header type 0 for chunk
0, data 0 -Process= "SSLVPN_PROCESS", ipl= 0, pid= 265, -Traceback= 0x61898E8C
0x6002DFC4 0x63D802FC 0x63D70C64 0x63D78A5C 0x63D79054 0x63D7986C 0x63D736A8
2) The webvpn login page is not thrown up at all when we try to connect  to the webvpn gateway. The 'Page is not displayed' due to the following  Traceback
May 10 21:57:30.963 PDT: %SYS-2-CHUNKINVALIDHDR: Invalid chunk header type 0 for chunk
0, data 0 -Process= "IP Input", ipl= 0, pid= 120, -Traceback= 0x61898E8C 0x6002DFC4
0x63D6D564 0x63D72F48 0x63D5C804 0x62285B20 0x62288158 0x61F81940 0x61F83264
0x61F8367C 0x61F83738 0x61F83980
Conditions: This can happen if WebVPN configuration is being removed and a client tries to connect.
Workaround: Avoid removing WebVPN configuration once it is configured
I don´t have any web vpn configuration. So, do you have any idea? The router is working perfectly but i am afraid for what could happen in the future.
Thanks in advance,
Raúl
vragotha
Level 3
Level 3
Can you post a 'show version'
Yes.
ROUTER_HOSTNAME#show version
Cisco IOS Software, C870 Software (C870-ADVIPSERVICESK9-M), Version 12.4(15)T10, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 14-Sep-09 23:35 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)YI4, RELEASE SOFTWARE
ROUTER_HOSTNAME uptime is 6 days, 21 hours, 1 minute
System image file is "flash:c870-advipservicesk9-mz.124-15.T10.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 871 (MPC8272) processor (revision 0x300) with 118784K/12288K bytes of memory.
Processor board ID FHK1405712G
MPC8272 CPU Rev: Part Number 0xC, Mask Number 0x10
5 FastEthernet interfaces
128K bytes of non-volatile configuration memory.
28672K bytes of processor board System flash (Intel Strataflash)
Thanks a lot for your quick response.
Raúl
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtc12321
The bug is fixed in 12.4(15)T12 or higher releases
This is more of a cosmetic issue.
Thank you!!
so, i´ll upgrade to T12 version
Thanks a lot!!
