Bookmark
Subscribe
1629
Cisco 1100 - Dual WAN Load Balancing
alexander2003
could one of you take a look at my configuration. I am trying to set up dual WAN load balancing on my Cisco 1111 router. However, I do not manage to do it. The computer gets assigned an IP address using DHCP, but cannot access any website. A ping to 8.8.8.8 is possible though. However, no other IP address can be pinged, not even from the ISP routers.
Thank you for help
version 16.6
service password-encryption
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname Cisco_Router_1111
boot-start-marker
boot-end-marker
no aaa new-model
ip name-server 8.8.8.8
no ip domain lookup
ip dhcp excluded-address 10.60.4.1
ip dhcp pool dpool_IP_Device
 network 10.60.4.0 255.255.254.0
 default-router 10.60.4.1
 domain-name network.intern
 dns-server 10.60.4.1
subscriber templating
diagnostic bootup level minimal
redundancy
 mode none
vlan internal allocation policy ascending
vlan 1034
 name Network_VLAN
interface GigabitEthernet0/0/0
 description ISP 1 WAN
 ip address dhcp
 ip nat outside
 negotiation auto
interface GigabitEthernet0/0/1
 description ISP 2 WAN
 ip address dhcp
 ip nat outside
 negotiation auto
interface GigabitEthernet0/1/0
 switchport access vlan 1034
interface GigabitEthernet0/1/1
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
interface GigabitEthernet0/1/4
interface GigabitEthernet0/1/5
interface GigabitEthernet0/1/6
interface GigabitEthernet0/1/7
interface Vlan1
 no ip address
interface Vlan1034
 ip address 10.60.4.1 255.255.254.0
 ip nat inside
 ip policy route-map LOAD_BALANCING
ip nat inside source list NAT_ACL interface GigabitEthernet0/0/0 overload
ip nat inside source list NAT_ACL_2 interface GigabitEthernet0/0/1 overload
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip dns server
ip route 0.0.0.0 0.0.0.0 192.168.1.0 track 1
ip route 0.0.0.0 0.0.0.0 192.168.0.1 track 2
ip access-list standard NAT_ACL
 permit 10.60.4.0 0.0.0.255
ip access-list standard NAT_ACL_2
ip access-list extended LOAD_BALANCING
 permit ip any any
route-map PBR-LOAD_BALANCING permit 10
 match ip address LOAD_BALANCING
 set interface GigabitEthernet0/0/0 GigabitEthernet0/0/1
control-plane
line con 0
 transport input none
 stopbits 1
line vty 0 4
 login
end
Hi Freind, I think I send you solution before!! or this new network ?
alexander2003
Unfortunately, I could not solve the last problem, so now I tried another option with using load balancing.
Configuring Dual ISP load balancing on Single Cisco Router - Overview For today network with - Studocu
check this guide please, if one point not clear just ask me and I will reply
