Cisco 15.x ISR G2 Router Crashes / Hangs When Doing NAT
casanavep
Level 3
Level 3
Has anyone seen issues on Cisco ISR / ISR G2 routers running 15.x  code while doing NAT for large quantities of users (3000+) involving lock ups? This seems to be an ongoing issue for a customer. The symtom is present on 2811, 2911 and a 3945. The 3945 never spikes over 10% processor or memory utilization, yet still has these issues. The routers have been tested running 15.0(1)M5, 15.0(1)M7 and 15.1(4)M4 which all showed simular results. Other router side services are running such as NetFlow v9 to two destinations. Another interesting symtom, doing a "show ip nat translations" command will crash the router if executed at its peak usage period. NAT is to a single IP (sourced from outside interface), not a pool.
HOSTNAME#show mem alloc total
                Head    Total(b)     Used(b)     Free(b)   Lowest(b)  Largest(b)
Processor   1231A16C   753819284    91719528   662099756   647785156   629474108
      I/O   3C200000    65011712    14865036    50146676    50146676    50145724
HOSTNAME#show mem debug leak chunk
Adding blocks for GD...
                 I/O memory
Address   Size   Alloc_pc PID Alloc-Proc       Name
Chunk Elements:
AllocPC Address Size Parent   Name
                 Processor memory
Chunk Elements:
     NA 20A597C     8 13CF9CD4 (IPnat RAS appl )
     NA 20A5984    8 13CF9CD4 (IPnat RAS appl )
     NA 20A5994     8 13CF9CD4 (IPnat RAS appl )
     NA 20A59A4     8 13CF9CD4 (IPnat RAS appl )
     NA 20A59AC     8 13CF9CD4 (IPnat RAS appl )
5E193EC 148378C0   12 145E39C0 (MallocLite)
5E193EC 148378DC   12 145E39C0 (MallocLite)
5E193C8 1483794C   12 145E39C0 (MallocLite)
5E193EC 14837968   12 145E39C0 (MallocLite)
5E193C8 148379A0   12 145E39C0 (MallocLite)
5E193EC 148379BC   12 145E39C0 (MallocLite)
5E193C8 1483E738   12 145E39C0 (MallocLite)
5E193C8 1483E770   12 145E39C0 (MallocLite)
5E193EC 1483E7C4   12 145E39C0 (MallocLite)
5E193C8 1483E818   12 145E39C0 (MallocLite)
paolo bevilacqua
Crashes and freezes under heavy utilization are not surprising considering the poor testing that Cisco does.
You will need to engage the TAC, patiently prove your case, and demand a solution.
You can also configure a shorther translation expiration in the hope that helps.
