Cisco 1712: Mac OS X management software
tobiaseichner
I look for a management software for my Cisco 1712 router that works under Mac OS X. Currently I manage it over the webpanel, but this does not provide me with access to the firewall settings, because our ISP has added ACLs. But exactly these I need to check now.
b.speltz
Level 4
Level 4
SNMS could be used as a management software for 1712and is supported from IDU 5 onwards with the minimum IOS versions of 12.2.15-ZL and 12.2(13)ZH . Refer the following URL for more information
http://www.cisco.com/en/US/products/sw/cscowork/ps2408/products_installation_guide_chapter09186a00801bc975.html
I'll have a look, thank you, although it seems at first glance that this software is intended for Windows systems.
