Cisco 1721 doesn't show a reload in the log
Philidor
Sh ver is showing that yesterday at about noon router was switched off and on and after the reset wan connection restarted to work
 uptime is 20 hours, 52 minutes
System restarted at 11:58:26 NFT Wed Sep 14 2022
System image file is "flash:c1700-sy-mz.122-15.T17.bin"
But show log is only showing a previous reload occurred in the middle of the night
Sep 14 03:24:02.243: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0, changed state to up
Sep 14 03:24:02.856: %SYS-5-CONFIG_I: Configured from memory by console
Sep 14 03:24:05.092: %SYS-5-RESTART: System restarted --
IOS (tm) C1700 Software (C1700-SY-M), Version 12.2(15)T17, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Fri 12-Aug-05 23:30 by kehsiao
Sep 14 03:24:05.116: %SNMP-5-COLDSTART: SNMP agent on host is undergoing a cold start
Sep 14 03:24:05.156: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
Sep 14 03:24:06.156: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1, changed state to up
#sh clock
08:52:16.678 NFT Thu Sep 15 2022
Seb Rupik
Hi there,
If the device is being manually power cycled then it will not have a chance to log that event. A restart initiated via the software will have an opportunity to log the event before the restart is initiated.
The output: 'System returned to ROM by power-on' , is your only indication that the device can give you that it was manually power cycled.
cheers,
Seb.
Seb Rupik
Hi there,
cheers,
Seb.
