Cisco 1721 Router Problem
aleemuddin
Hi, can anybody suggest..
when i connect consol of cisco 1721 Router.
the display is in junk like ..
2}2}2}2}2}2}2}2}2}2}2}2}2}2}2}2}2}2}2}2}2}2}2}2}2}2}2}2}2}2}2}2}2}2}2}2}2}2}2}
2}2}2}2}2}
I could not able to see anything.. setting on hyper terminal are default like
bits :9600
data bits: 8
parity :None
stops bits: 1
flow control :none
pkhatri
Level 11
Level 11
It's possible that the router's console settings have been changed. You might want to try a range of baud rates on your terminal emulation program starting from 19200....
Pls do remember to rate posts.
Paresh
hi paresh.
Thanks for reply. i tried with all b-rates on terminal program but no response. everytime i change different output like
òý ‹z ý y! _ «ú rý‚ä ëüý‚d ÷ýý÷ ýòƒb ý ýë ýr‹z ƒb ÷ý‹z ýë ý
give some another solution please. looking for early reply
Thanks. bye
