Cisco 1721 WIc-1ADSL problems
skavenger0
Hi All,
I really hope someone can help me as I am struggling to solve this one. I can't see what is wrong.
I am trying to configure it to run on ADSL but I am getting large amounts or errors when I run "sh dsl int atm0" and can't work out why?
I am getting large quantities of Reed Solomon EC and then large bursts of CRC and Header errors.
Its causing my line to fall over quite alot. It appears stable at first but then all of a sudden errors start and it dies.
If I do "debug atm errors" I get alot of errors saying somthing along the lines of tsi not available.
Does anyone have any ideas?
This is my config:
version 12.2
hostname stardock
boot system flash:C1700-y7-mz.122-15.T16.bin
logging queue-limit 100
enable secret 5 $1$7sgG$8C0ncXbNHlSwyIgLkePkN/
enable password *PASSWORD*
username all
ip subnet-zero
no ip domain lookup
ip name-server 62.24.199.13
ip name-server 62.24.199.23
ip dhcp excluded-address 192.168.10.1
ip dhcp excluded-address 192.168.10.254
ip dhcp excluded-address 192.168.10.10
ip dhcp excluded-address 192.168.10.3
ip dhcp pool InternalDHCP
   network 192.168.10.0 255.255.255.0
   default-router 192.168.10.254
   dns-server 62.24.199.13 62.24.199.23
ip cef
interface ATM0
no ip address
no ip route-cache
no atm ilmi-keepalive
bundle-enable
dsl operating-mode auto
hold-queue 224 in
interface ATM0.1 point-to-point
no ip route-cache
pvc 0/38
  encapsulation aal5mux ppp dialer
  pppoe max-sessions 1
  dialer pool-member 1
interface BRI0
no ip address
shutdown
interface FastEthernet0
ip address 192.168.10.254 255.255.255.0
ip nat inside
speed auto
full-duplex
interface Dialer0
no ip address
interface Dialer1
ip address negotiated
ip mtu 1432
ip nat outside
encapsulation ppp
dialer pool 1
ppp authentication chap callin
ppp chap hostname *USERNAME*
ppp chap password 0 *PASSWORD*
ip nat inside source list 1 interface Dialer1 overload
ip nat inside source static 192.168.10.10 interface Dialer1
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
access-list 1 permit 192.168.10.0 0.0.0.255
line con 0
logging synchronous
line aux 0
line vty 0 4
password *PASSWORD*
login
end
10 Replies 10
Giuseppe Larosa
Hello Richard,
you should have posted a show dsl interface atm0
Reed Solomon errors are errors at OSI layer 1 in the DSL contact the  DSL service provider and ask them to check the line.
Likely the signal to noise ratio is too low in one direction or on both directions, this can be seen in the show dsl interface atm0 ( referred as noise margin one per direction)
Your configuration looks like correct.
Hope to help
Giuseppe
Thanks, I was giong to post the show dsl interface atm0 but I had just cleared it so it was clean. As soon as I get some data I will do.
Thanks for checking my config.
Do you know how I can control my SNR in 12.2 as I have been struggling to pin down the commands pre-12.3?
This is my current atm but as I said the errors come in waves and I havnt had them turn up yet.
stardock#sh dsl int a0
Alcatel 20150 chipset information
                ATU-R (DS)                      ATU-C (US)
Modem Status:    Showtime (DMTDSL_SHOWTIME)
DSL Mode:        ITU G.992.1 (G.DMT)
ITU STD NUM:     0x01                            0x1
Vendor ID:       'ALCB'                          'IFTN'
Vendor Specific: 0x0000                          0x71C6
Vendor Country:  0x00                            0xB5
Capacity Used:   96%                             100%
Noise Margin:     5.5 dB                          6.0 dB
Output Power:    19.5 dBm                        12.0 dBm
Attenuation:     51.5 dB                         31.5 dB
Defect Status:   None                            None
Last Fail Code:  None
Selftest Result: 0x00
Subfunction:     0x15
Interrupts:      1438 (0 spurious)
PHY Access Err:  0
Activations:     13
Init FW:         embedded
Operation FW:    embedded
SW Version:      3.8131
FW Version:      0x1A04
                 Interleave             Fast    Interleave              Fast
Speed (kbps):          3904                0           800                 0
Reed-Solomon EC:        133                0            39                 0
CRC Errors:               9                0            35                 0
Header Errors:            4                0            14                 0
Bit Errors:               0                0
BER Valid sec:            0                0
BER Invalid sec:          0                0
DMT Bits Per Bin
00: 0 0 0 0 0 0 0 6 7 9 A B B B B B
10: B B B C B B B B B A A 9 8 8 0 0
20: 0 0 0 0 0 0 8 9 9 A A B B B 9 B
30: B B B C C C C C C C C B B C C C
40: C C C 2 B B B B B B B B B A A A
50: A A B A A A A A A A A 9 8 A 9 9
60: 9 9 9 9 8 9 9 A 9 A 9 9 8 8 7 8
70: 8 9 9 9 9 9 8 8 8 8 7 8 8 6 6 7
80: 7 7 7 7 6 0 7 7 7 7 6 6 6 5 6 6
90: 6 6 6 0 6 6 6 6 0 5 6 5 5 4 4 3
A0: 0 0 2 3 3 3 3 2 4 4 4 3 2 2 4 3
B0: 4 4 4 3 3 3 2 2 2 2 0 2 2 2 2 0
C0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
D0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
E0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
F0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
DSL: Training log buffer capability is not enabled
It appears the issue is with my SNR it keeps dropping into the negatives, as low as -15.
I've tried looking online but I cannot find any commands to fix or control the SNR. Any Ideas?
Contact your DSL provider and give them your output.  They should know what to do.
Hello Richard,
as suggested by Leo contact the DSL provider
to be noted also on your show dsl interface we see a positive SNR but with excessive downstream attenuation of 51.5 dB
The line is not clean
Hope to help
Giuseppe
Yes, I am quite a distance from the exchange but was getting consitent 4mbps with an SNR of 6dB on my Netgear 834G. So its definately an issue caused by the change over to using Cisco equipment.
I wish I could just find a way to fix the SNR to a set figure rather than have it auto negotiate.
I'm going to raise a support ticket with the ISP aswel, I just thought there should be someway of solving this on my end.
I've just been rechecking me config and I think my ISP needs PPPoA. I am with TalkTalk http://help.talktalk.co.uk/app/answers/detail/a_id/1400/~/the-dsl-light-on-my-router-is-on-but-i-can't-connect
Could that cause such issues?
Any ideas how I make sure I am using PPPoA, my opinion of my config is that its set to PPPoE but I would have thought that would just prevent connection at all?
Hello Richard,
your issues are not related to a wrong encapsulation that would cause total lack of IP connectivity.
Your current configuration could be defined PPPoEoA just to add confusion in the naming!
Your issues are related to the line at OSI physical layer.
Hope to help
Giuseppe
Ah the
is auto detection and it takes care of the vc-mux. I'm on the right page now. Thanks for that.
looks like I'm going to have to try new cables + filters etc then or concider switching back to a standard ADSL modem/router.
TalkTalk tech support is bloody awful.
I agree with Giuseppe here.
Your issue has got nothing to do with your configuration.  It's got something to do with your physical line.  Granted your service degraded after you switched to Cisco but that's not the point.  Your physical line is awful or dirty.
