BGP with HSRP. BGP is creating problem.
prashantrecon
I have 3 cisco 2800.
R1 is my main router which is working fine with it,s bgp.
Now I have configure bgp with hsrp on R2 and R3 as
Router R2 config :
Router#sh running-config
Building configuration...
Current configuration : 1600 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
logging message-counter syslog
enable password cisco
no aaa new-model
memory-size iomem 5
dot11 syslog
ip source-route
ip cef
no ipv6 cef
voice-card 0
no dspfarm
archive
log config
  hidekeys
interface FastEthernet0/0
ip address 203.x.x.223 255.255.255.0
duplex auto
speed auto
standby 1 ip 203.x.x.225
standby 1 priority 120
standby 1 preempt
interface FastEthernet0/1
ip address 202.x.x.2 255.255.255.0
duplex auto
speed auto
router bgp 45000
bgp log-neighbor-changes
neighbor 202.x.x.1 remote-as 18101
address-family ipv4
  neighbor 202.x.x.1 activate
  neighbor 202.x.x.1 route-map reliance-in in
  neighbor 202.x.x.1 route-map reliance-out out
  no auto-summary
  no synchronization
  network 203.x.x.0
exit-address-family
ip forward-protocol nd
no ip http server
no ip http secure-server
ip prefix-list default seq 5 permit 0.0.0.0/0
ip prefix-list r-out seq 5 permit 203.x.x.0/24
route-map r-in permit 10
match ip address prefix-list default
set local-preference 500
route-map r-out permit 10
match ip address prefix-list r-out
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
password x.x.x.x
login
scheduler allocate 20000 1000
end
My main router R1 is working fine with it,s old bgp configure.
My hsrp woth router R2 and R3 is working fine.
At starting I think my bgp with hsrp is working fine on r2 and r3.
But after some times bgp configure on R2 is starting to create problem on my Main router R1.(My VPN on R1 is affecting once R2 start )
Note: I am using my Apnic ip range on both R1 (main) and R2
Note: R1 and R2 are not in same LAN.
5 Replies 5
Peter Paluch
Hello Prashant,
Please help us understand your configuration better before we can give advices:
  1. Can you post a picture of your network topology so we can understand how your network is connected, where are the BGP routers and where is the HSRP deployed?
  2. What is the purpose of using HSRP here? Is it there to provide a redundant gateway to end hosts? Please note that the HSRP is not generally intended to be used between routers. Routers have routing protocols to provide for redundancy.
  3. What exactly does it mean that "bgp configure on R2 is starting to create problem on my Main router R1."?
Best regards,
Peter
1: Please find a diagram.All three router are in same place but R1 is in diffrent LAN network.R 2 and R3 are configure as BGP with hsrp for another LAN network.HSRP is configured for r2 and r3.
2: YES for router redudancy .
3:R1 is already in production ok once r2 and r3 start working after some time my VPN for R1 router is affected also websites is not opening.
Hello Prashant,
Thank you for the diagram and the answers.
I am still not certain about the nature of your problem. If I understand you correctly, the Site A that uses R1 is working fine and its own internet connectivity is not affected. Is this correct?
You are saying that once R2 and R3 start working, after some time, your VPN for R1 router is affected. How affected?
  1. What kind of VPN is used? GRE, IPsec, GRE-over-IPsec, SSL?
  2. What are the VPN tunnel endpoints? Where are the VPN clients located and where/what is the access concentrator, i.e. the opposite side of the VPN connection?
  3. What exactly do you mean by "VPN is affected"? Does that mean that the VPN connections are torn down? Does the VPN connectivity fail entirely?
Can you also perform some basic troubleshooting and data gathering when the connectivity is affected, like performing a ping and/or traceroute and seeing if the traffic goes the proper way, optionally where does it get misrouted or lost?
I apologize for not being able to provide any more help right now. I am still trying to understand which site is having problems, how do the problems manifest themselves (but in more precise terms, not just by concluding "it's not working" - that does not help at all), what is the possible role of BGP in creating this issue, etc.
Oh, by the way, did these problems first appear when you implemented HSRP? Was your network working correctly without HSRP?
Best regards,
Peter
question is
there are there router
scenario 1
One router is running bgp  0.0.0.0 n/w is adverisites  at out direction
and 203.x.x.x n/w adversited at in direction.
snerio 2
two routers with bgp running and hsrrp
as you can observe 0.0.0.0 n/w is adverisites  at out direction
snerio 1 is working fine.
when i bring scenerio 2 in to production for different lan
Than scenario 1 gets affected like ipsec vpn gets affected.
Note - scenario 1 and senario have no link two each other .
Is that while returing back for 203.x.x.x traffic bgp is geeting affected ?
Can anyone suggest
