09-17-2007 01:00 PM - edited 03-03-2019 06:47 PM
I see in the data sheet that my 1760 can take a variety of WIC's. I need to expand my data pipe from 1.5Mb to 3.0Mb and was wondering if the 1760 can accomodate (2) T1-WIC's or a WIC with (2) integrated T1 BRI interfaces (I believe Cisco makes such a WIC)?
Solved! Go to Solution.
09-17-2007 01:09 PM
Yes, it can. Note the '2 x T1 BRI' is actually called VWIC-2MFT-T1, or VWIC-2MFT-T1E1.
Nothing to do with BRI that is something else.
09-17-2007 01:09 PM
09-21-2007 08:23 AM
Thanks so much! I appreciate your support. I will have to get another WIC-1DSU-T1-V2, as the VWIC-1MFT-T1 WIC will not work in a 1760, only Cisco 2600, 2800, 3600, 3700 and Cisco 3800 series. Thanks again!
