Cisco 1760 Console Error
bozhidar_1997
Hi can you please help me with a problem with my cisco 1760 router. The problem is that the router outputs in the console
▒`g▒_7[▒▒▒▒f▒e▒▒s#▒▒▒'▒ܱ▒▒Z▒▒
                            ۔3▒r0ndYα▒6▒▒▒ڸ^▒▒lc▒▒ܫ▒'▒▒&▒tK
                                                           ▒e▒▒=Y▒▒5▒
can you please help me decypher this text and why are it is outputing like this?
Thank you
Richard Burts
The most common cause of this symptom is that there is a mismatch between the speed of the console port and the speed specified in the terminal emulator (Hyperterm, TeraTerm, SecureCRT, or whatever emulator that you are using). I suggest that you set the speed of the emulator starting at 1200, and working up through 2400, 4800, etc. Be aware that with some emulators that when you change the speed you need to stop and restart the connection to pick up the new speed.
Rick
Rick
