Cisco 1801: Multiple Bridging
t4tauseef33
Hi All,
I have cisco 1801 router with 8 ports.
I am trying to setup two different vlans on this equipment. fa 1 is connected to my LAN and Fa 2 is connected to my WAN.
I want to have a vlan 1 used by Fa 0 and vlan 2 used by fa 2. Can you please check my config and let me know of any configuration problem?
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
description $LAN$
no ip address
ip tcp adjust-mss 1452
bridge-group 1
interface Vlan2
description $WAN$
no ip address
bridge-group 2
interface BVI1
description $LAN$
ip address 10.16.1.0 255.255.255.0
interface BVI2
description $WAN$
ip address 10.16.2.0 255.255.255.0
bridge 1 protocol ieee
bridge 1 route ip
bridge 2 protocol ieee
bridge 2 route ip
Giuseppe Larosa
Hello Tauseef,
by default all "switch" ports are in vlan1.
so under each interface that should be in vlan2 you should place
int fas X
switchport mode access
switchport access vlan 2
an example of config for 1801 is here
http://www.cisco.com/en/US/docs/routers/access/1800/1801/software/configuration/guide/sampconf.html
Hope to help
Giuseppe
