Cisco 1811 - Dual WAN - Routing issue?
DanielSheppard
I have a Cisco 1811 with both WAN ports setup.  Static routes for both on the router as well as route maps behind to support the individual vlans.  My problem states here.
On one port, which is a standard DSL to backup the office network, everything works fine(Ping, SSH, etc) to the router itself.  On the Fiber connection however, these all fail.  If however I attempt to connect to the router interface assigned to the third vlan(using a routed subnet off the fiber) it works.
I am thinking this is a routing issue but I cannot see where this falls down.  Any suggestions before I post a edited config?
DanielSheppard
Well, I figured it out sort of...
I wish I had gotten a show tech before I did though because this appears to be some sort of bug in 15.1(3)T
All that was required to fix was a shutdown of the Dialer interface and then bringing it back up.  After that the fiber interface was working again.
