Cisco 1811, How to get Internet access on my Laptop?
Daniel Jansma
Hi Guys,
Hope you can give me the last push :-)
I got a Cisco 1811, with on FA0  ( WAN ) acting as a dhcp client and on FA1 ( LAN ) my laptop wich is getting a address form the DHCP Pool.
I receive a ip address on my laptop but it doesn't know the way to get outside.
here is my config:
Building configuration...
Current configuration : 3498 bytes
version 12.4
hostname Router-1811
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 5 BLA BLA
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.200.0 192.168.200.100
ip dhcp pool DATA
   import all
   network 192.168.200.0 255.255.255.0
   dns-server 212.54.40.25
   default-router 192.168.200.1
   lease 8
crypto pki trustpoint TP-self-signed-1623916396
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1623916396
revocation-check none
rsakeypair TP-self-signed-1623916396
crypto pki certificate chain TP-self-signed-1623916396
certificate self-signed 01
  30820244 308201AD A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31363233 39313633 3936301E 170D3133 30313035 31363532
  35335A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 36323339
  31363339 3630819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100AD29 D515C443 92517F4B 903D97AC B3F744C0 93924489 1EBA9BD2 1C190B4B
  508A73A4 573A28DF F16F34CA 63597891 0D45E032 D9BA41E8 310CB984 D50C6C5F
  ED28F54B 928546F3 82A16C2D B20B27A7 62D151E7 FE782E18 5953E88E B0562053
  CA025DCE 256016A9 14E252D0 5EFCE00B 0C465FC6 C6D32468 78293624 B3C929F7
  B42D0203 010001A3 6C306A30 0F060355 1D130101 FF040530 030101FF 30170603
  551D1104 10300E82 0C526F75 7465722D 31383131 2E301F06 03551D23 04183016
  8014DFCF AC5FCFA1 06BB230A F1572513 1C6B9C10 D682301D 0603551D 0E041604
  14DFCFAC 5FCFA106 BB230AF1 5725131C 6B9C10D6 82300D06 092A8648 86F70D01
  01040500 03818100 4CD662F4 A0672668 3FF9F06A 8C5831DC 54702460 96564218
  A8A360F4 3E4849E5 341DA5A6 39B72549 2965DF3D 0DE03F18 081582CA CD13365E
  7F720EFE 35E4009D 1E169E19 69493B3E 0547DD4A 6CC4AADE 06AAFE42 57A4EC75
  B8921015 5808C313 67160206 5F4BDCB5 CE86BE59 A4D76930 768581C0 4F993CAA
  1A50842C 20BD9754
  quit
username admin privilege 15 password 0 BLA BLA
interface FastEthernet0
description WAN
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet1
description LAN
ip address 192.168.200.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface FastEthernet2
interface FastEthernet3
shutdown
interface FastEthernet4
shutdown
interface FastEthernet5
shutdown
interface FastEthernet6
shutdown
interface FastEthernet7
shutdown
interface FastEthernet8
shutdown
interface FastEthernet9
shutdown
interface Vlan1
description Lan2
no ip address
shutdown
interface Async1
no ip address
encapsulation slip
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0 permanent
ip http server
ip http authentication local
ip http secure-server
ip nat inside source list 1 interface FastEthernet0 overload
access-list 1 permit 192.168.200.0 0.0.0.255
control-plane
line con 0
line 1
modem InOut
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
line vty 0 4
privilege level 15
password ypsilon
login local
transport input telnet ssh
no scheduler allocate
end
ipconfig/all
ip: 192.168.200.102
sub: 255.255.255.0
GW: 192.168.200.1
DHCP server: 192.168.200.1
dns: 212.54.40.25 --> is my provider
show int fa0:
Router-1811#sh int fa0
FastEthernet0 is up, line protocol is up
  Hardware is PQ3_TSEC, address is 0015.6205.f7d8 (bia 0015.6205.f7d8)
  Description: WAN
  Internet address is 192.168.100.1/24
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:05, output 00:00:00, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     2142 packets input, 252317 bytes
     Received 1502 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog
     8349 packets output, 1224384 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     0 lost carrier, 0 no carrier
I turned on ip routing and  inserted: router(config)#ip nat inside source list 1 int fa0 overload
Still no go from laptop to the Internet. On the router i can't ping to external servers en domains any more. Can someone give me some tips? Thanks!!!
cadet alain
replace this:
by this:
ip route 0.0.0.0 0.0.0.0 dhcp
Regards.
Alain
5 Replies 5
cadet alain
replace this:
by this:
Regards.
Alain
What type is your WAN Connection?
At least you should change default gateway to IP address of WAN router instead of Interface.
You should use interface as default gateway in case you have pppoe connection for example.
Jeff Van Houten
Level 5
Level 5
Take the IP address off of fa1 and put it on vlan1 then "no shut" the vlan 1 interface.
Daniel Jansma
Thanks Alain, that was the correct answer!
maybe you can explain why it know works?
Thanks in advance!
it's working now because your default route is pointing towards the next-hop( that you got via dhcp) instead of the outgoing interface.HAving a static route pointing out a multipoint interface like ethernet can only work if the next-hop is implementing proxy-arp( which is a security concern and is so disabled by default on most devices).
Regards.
Alain
