Cisco 1811 vlan config issues
Chris Barron
All,
I am trying to configure a vlan for fa2-fa9 on my 1811.
What I "need" is for the vlan to forward to the dhcp server for IPs and allow internet access as well.
The helper address is the address for the dhcp server.
Any help would be great
Below is the conf......
Building configuration...
Current configuration : 3630 bytes
version 12.4
hostname router1.clmamo.cjcomputers.net
boot-start-marker
boot-end-marker
no logging console
enable secret 5 *******************************
enable password **********
aaa new-model
aaa authentication login local_auth local
aaa session-id common
dot11 syslog
ip cef
ip domain name cjcomputers.net
username cjcomputers password 0 *********
username admin privilege 15 secret 5 **********************************
username chris password 0 *********
crypto isakmp policy 1
 encr 3des
 authentication pre-share
 group 2
crypto isakmp client configuration group VPN-GROUP
crypto ipsec transform-set TRANSFORM-SET esp-3des esp-sha-hmac
crypto dynamic-map dynmap 10
archive
 log config
  hidekeys
ip ssh version 1
interface FastEthernet0
 description LAN Interface
 ip address 10.10.2.1 255.255.0.0
 ip helper-address 10.10.2.99
 ip nat inside
 ip virtual-reassembly
 duplex auto
 speed auto
interface FastEthernet1
description WAN Interface
 ip address dhcp
 ip nat outside
 duplex auto
 speed auto
interface FastEthernet2
 description test server
 switchport access vlan 2
interface FastEthernet3
 description server2.clmamo.cjcomputers.net
interface FastEthernet4
 description server3.clmamo.cjcomputers.net (DHCP)
interface FastEthernet5
 description server5.clmamo.cjcomputers.net (Win03)
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Vlan1
 ip address 9.9.9.9 255.255.0.0
 ip nat inside
interface Vlan2
 ip address 11.11.11.1 255.255.0.0
 ip access-group 103 in
 ip access-group 104 out
 ip nat inside
interface Async1
 no ip address
 encapsulation slip
no ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 dhcp
ip http server
ip http port 1025
no ip http secure-server
ip nat inside source list 101 interface FastEthernet1 overload
ip nat inside source static tcp 10.10.2.99 80 interface FastEthernet1 80
ip nat inside source static tcp 10.10.2.99 10001 interface FastEthernet1 10001
ip nat inside source static tcp 10.10.2.101 10000 interface FastEthernet1 10000
ip nat inside source static tcp 10.10.2.99 31 interface FastEthernet1 31
ip nat inside source static tcp 10.10.2.101 30 interface FastEthernet1 30
ip nat inside source static tcp 10.10.0.1 8080 interface FastEthernet1 8080
ip nat inside source static tcp 10.10.1.1 8081 interface FastEthernet1 8081
ip nat inside source static tcp 10.10.3.1 8082 interface FastEthernet1 8082
ip nat inside source static tcp 10.10.0.100 32 interface FastEthernet1 32
ip nat inside source static tcp 10.10.2.100 3389 interface FastEthernet1 3389
ip nat inside source list 102 interface FastEthernet1 overload
access-list 101 permit ip 10.10.0.0 0.0.255.255 any
access-list 102 permit ip 11.11.0.0 0.0.255.255 any
access-list 103 permit ip 10.10.0.0 0.0.255.255 11.11.0.0 0.0.255.255
access-list 104 permit ip 11.11.0.0 0.0.255.255 10.10.0.0 0.0.255.255
snmp-server community public RO
control-plane
line con 0
line 1
 modem InOut
 stopbits 1
 speed 115200
 flowcontrol hardware
line aux 0
line vty 0 4
 password ****************
 login authentication local_auth
 transport input ssh
end
Chris Barron
Any Ideas???? Anyone?????
