Cisco 3845 with high CPU and Interupt
CiscoNutt
I have a 3845 running IOS version 15.1(4)M8 which has very high CPU and interupt:
CPU utilization for five seconds: 73%/70%; one minute: 78%; five minutes: 75%
 PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
  64   128368276     5188871      24739  1.12%  1.15%  1.14%   0 Per-Second Jobs
 362    21040940  1224481386         17  0.80%  0.91%  0.91%   0 IP SLAs XOS Even
  90        2424         651       3723  0.32%  0.06%  0.01% 706 SSH Process
 123     9922532   642308913         15  0.32%  0.33%  0.32%   0 Ethernet Msec Ti
 223     7175980  1222858710          5  0.24%  0.28%  0.30%   0 HQF Shaper Backg
 358     8225664   314776930         26  0.24%  0.23%  0.23%   0 HSRP Common
   2     1738752     1037228       1676  0.08%  0.08%  0.08%   0 Load Meter
 303     5476208     6197476        883  0.08%  0.08%  0.05%   0 Crypto PAS Proc
 143     7143280    21090388        338  0.08%  0.07%  0.06%   0 IP Input
 139     2105108   157888159         13  0.08%  0.05%  0.06%   0 IPAM Manager
The interface input / output rates are not near the Bandwidth limit of the interfaces.  Our Smarteye server shows normal CPU levels.  So I am wondering if this is just a cosmetic thing with the router?
It also doesn't seem to be CEF but I have not tried disabling it.
Logging show only the occasional rekey for GET VPN.
5 Replies 5
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
A 3845, generally, does not have the capacity for it's gig LAN interfaces, as it's a WAN router recommended for up dealing with a single DS3.
If you're doing VPN on the router, that will add to the CPU, especially if the router also needs to deal with packet fragmentation.
I am not familiar with DS3, what is it?
The router is acting as a CE router but does not do any inter-VLAN routing, only a gateway to the IPVPN network. And we are running GET VPN on it.
Disclaimer
Posting
It's a serial WAN link that supports 45 Mbps.
3845's are good for about 200 Mbps, or so, of aggregate Ethernet bandwidth.  (Again, if your VPN is dealing with fragmentation, CPU consumption, per Mbps, will be higher.)
What the sum of all your ingress (or egress) interface bandwidths when your CPU usage is high?
Ashok Kumar
High CPU due to interrupt, let me give a very brief and concise information-
1. CPU consumed by Interrupt = CPU consumed in packet switching + CPU consumed features configured
2. There's 2 ways to handle the features configured/packet switching, either in the hardware or in software
3. If your device doesn't support the hardware switching/ACL/QoS implementation, more you configure the feature, more high you going to get the CPU
4. Below is the very good guide to troubleshoot the high CPU due to interrupt
http://www.cisco.com/c/en/us/support/docs/routers/7500-series-routers/41120-highcpu-interrupts.html
- Ashok
Please rate the post or mark as correct answer as it will help others looking for similar information
Thanks Ashok,
I have already seen this webpage but it did not help much in pinpointing the issue.
