Dear Friends,
I have a Cisco 1841 with 1 WAN connection (ATT) receiving a Public IP Addresses /29 and we have a static NAT to map it to private IP Addresses and we are using Dynamic DNS to use a name instead of IP Address to connect to this site (I am not sure if i can use the Dynamic DNS as load balance or not!)
We are going to add a second connection to this router (Comcast) and I was wondering what is the available load Balance methods to incoming & outgoing traffic?
Also if we decided to go with using Comcast as the primary connection and ATT as the Backup what is the best implementation to reduce the failover time?
Finally, I need to add a new VLAN and connect it to the Wireless Router, so what is the easier way to configure low priority to the Wireless users?
Thanks a lot
