취소
다음에 대한 결과 표시
다음에 대한 검색
다음을 의미합니까?
VIEWS
답글
cisco 1841 3G WWAN HWIC-HSDPA/UMTS/EDGE/ not working
ovidiustatar
I'm just wondering why I cannot see the modem and hardware version if I'm running sh cellular 0/0/0 all . Is there something that I need to active before ?  Or is there a issue with the hardware module ?
R1#sh cellular 0/0/0 all
Hardware Information
Modem Firmware Version =
Modem Firmware built =
Hardware Version =
International Mobile Subscriber Identity (IMSI) = 00000
International Mobile Equipment Identity (IMEI) =
Integrated Circuit Card ID (ICCID) =
Mobile Subscriber International Subscriber
IDentity Number (MSISDN) =
Factory Serial Number (FSN) =
Modem Status = Offline
Current Modem Temperature = 0 deg C, State = Normal
PRI SKU ID = 0, SKU Rev. = 0.0
sh diag
WIC/HWIC Slot 0:
3G WWAN HWIC-HSDPA/UMTS/EDGE/GPRS-850/900/1800/1900/2100MHz
Hardware Revision : 1.0
Top Assy. Part Number : 800-28846-01
Board Revision : J0
1#sh version
Cisco IOS Software, 1841 Software (C1841-SPSERVICESK9-M), Version 15.1(4)M12a, RELEASE SOFTWARE (fc1)
The full configuration attached by :
R1#sh run
Building configuration...
Current configuration : 1670 bytes
! No configuration change since last restart
version 15.1
hostname R1
boot-start-marker
boot system flash flash:c1841-spservicesk9-mz.151-4.M12a.bin
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip domain name my.net
no ipv6 cef
chat-script gsm-script "" "ATDT*99*1#" THMEUO 30 "CONNECT"
license udi pid xxxx sn xxxxx
username xxx password 0 xxxx
username xxxx privilege 15 password 0 xxxxx
controller Cellular 0/0
ip telnet source-interface Loopback10
ip ssh rsa keypair-name ssh
 ip address 3.3.10.2 255.0.0.0
interface FastEthernet0/0
 ip address dhcp
 speed auto
 full-duplex
interface FastEthernet0/1
 ip address 1.1.1.2 255.0.0.0
 duplex auto
 speed auto
interface Cellular0/0/0
 ip address negotiated
 encapsulation ppp
 shutdown
 dialer in-band
 dialer idle-timeout 60
 dialer string gsm-script
 dialer-group 1
 async mode interactive
 ppp authentication chap callin
 ppp chap hostname web.vodafone.de
router bgp 1
 bgp log-neighbor-changes
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 Cellular0/0/0
access-list 10 permit any
dialer-list 1 protocol ip list 10
control-plane
line con 0
line aux 0
line 0/0/0
 script dialer gsm-script
 no exec
line vty 0 4
 login local
 transport input ssh
scheduler allocate 20000 1000
end
R1#
R1#sh cellular 0/0/0 radio
Radio power mode = OFF, Reason = Unknown
Current Band = None, Channel Number = 0
Current RSSI = -0 dBm
Band Selected = not selected due to invalid band mask
R1#
  • WAN
9 응답 9
do you get any output with:
show controller cellular 0/0
Try and unshut the cellular interface:
encapsulation ppp
--> no shutdown
dialer in-band
dialer-group 1
OK interface is set to "no nut" but get same issues no mobile and hardware version and get only message  "%CELLWAN-2-SEND_TIMEOUT: Cellular0/0/0 not responding"
R1#sh ip int brief
Jan  2 12:02:00.491: %SYS-5-CONFIG_I: Configured from console by console
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            unassigned      YES DHCP   up                    down
FastEthernet0/1            1.1.1.2         YES NVRAM  up                    down
Cellular0/0/0              unassigned      YES NVRAM  down                  down
Loopback10                 3.3.10.2        YES NVRAM  up                    up
R1#
Jan  2 12:02:00.803: %LINK-3-UPDOWN: Interface Cellular0/0/0, changed state to down
R1#
R1#sh control cellular 0/0/0
HSDPA/UMTS/EDGE/GPRS-850/900/1800/1900/2100MHz unit 0,
HWIC cellular modem configuration:
Modem is not recognized as valid for this HWIC
manufacture id:  0x00000000     product id: 0x00000000
Modem with unknown manufacture id or product id.
GPS State: GPS disabled
Modem Management Statistics
Modem resets = 0
Last known modem state = 'boot & hold' mode
Packets sent = 0, Packets received = 0, Packets pending = 0
RSSI  LED = OFF
UMTS  LED = OFF
HSDPA LED = OFF
GPS NMEA port = Disabled   (Stream OFF)
DM port = Disabled
Nios registers:
Nios reset register = 0x1050B
Nios PC Trace Buffer Pointer register = 0x2A98
PLL1 = Locked          PLL2 = Locked          PLL3 = Locked
R1#sh cell
Hardware Version =
Profile Information
 * - Default profile
Data Connection Information
Data Transmitted = 0 bytes, Received = 0 bytes
Profile 1, Packet Session Status = INACTIVE
 --More--
Jan  2 12:03:53.895: %CELLWAN-2-SEND_TIMEOUT: Cellular0/0/0 not responding
--> Modem is not recognized as valid for this HWIC
This means you have a hardware compatibility issue. Post the output of:
sh ver
sh version
R1#sh ver
R1#sh version
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Tue 04-Oct-16 03:12 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
R1 uptime is 54 minutes
System restarted at 11:59:36 UTC Mon Jan 2 2006
System image file is "flash:c1841-spservicesk9-mz.151-4.M12a.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 1841 (revision 7.0) with 118784K/12288K bytes of memory.
Processor board ID FCxxxxxx
2 FastEthernet interfaces
1 terminal line
1 Cellular interface
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62720K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO1841             FCZxxxxxxxx
I found this document listing modules for 1841 and 1851
https://www.cisco.com/c/en/us/products/routers/1800-series-integrated-services-routers-isr/relevant-interfaces-and-modules.html
Using the information from the show diag in the original post
sh diag
WIC/HWIC Slot 0:
It looks like your HWIC-HSDPA is valid on 1861 but not 1841.
Rick
same issue also on 1861
yourname#sh version
Cisco IOS Software, C1861 Software (C1861-ADVIPSERVICESK9-M), Version 15.0(1)M4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Thu 28-Oct-10 16:15 by prod_rel_team
ROM: System Bootstrap, Version 12.4(11r)XW3, RELEASE SOFTWARE (fc1)
yourname uptime is 35 minutes
System image file is "flash:c1861-advipservicesk9-mz.150-1.M4.bin"
yourname#
yourname#sh cellular  0/2/0  hardware
Hardware Version =
yourname#
there are three different flavors of your card:
HWIC-3G-HSPA
HWIC-3G-HSPA-A
HWIC-3G-HSPA-G
Which one do you have ? Each card only works in specific regions. Check Table 1 in the attached document:
https://www.cisco.com/c/en/us/products/collateral/interfaces-modules/3g-wireless-wan-high-speed-wan-interface-card/product_data_sheet0900aecd80600f41.html
HWIC-3G-GSM V01
       HWIC Slot 2:
        Board Revision           : J0
        Deviation Number         : 0
        Fab Version              : 03
        PCB Serial Number        : FOC134542B8
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Fab Part Number          : 28-7666-03
        Manufacturing Test Data  : 00 00 00 00 00 00 00 00
        Field Diagnostics Data   : 00 00 00 00 00 00 00 00
        Product (FRU) Number     : HWIC-3G-GSM
        Version Identifier       : V01
        CLEI Code                : COUIAKTCAA
