Help with NAT and ACL on C800 Series
Veridizer
I would like to request some help with making a few changes to this router, in order to get access from outside.
I have tried to do it myself but I have caused more damage than good. This is because I am honestly not at all familiar with the concept. Instead of giving up, I am counting on getting help from the experts. If anyone can provide the exact commands required to get it to work, then I would be forever grateful.
The requirements are as follows:
From the WAN side, all external connections to the Computers Vlan on TCP 2400 should be allowed.
From the WAN side, all external connections to the DMZ Vlan, host 192.168.10.10 UDP 1820 should be allowed.
From the DMZ end, all internal connections from the host 192.168.10.10 to the router 192.168.10.1 using SNMP should be permitted.
From the DMZ end, all internal connection from the host 192.168.10.10 to the router 192.168.10.1 using SSH should be permitted.
Here is the (obfuscated) config:
no service timestamps debug uptime
no service timestamps log uptime
hostname Router
boot-start-marker
boot-end-marker
logging buffered 32000
no logging console
aaa new-model
aaa authentication login default local
aaa authorization console
aaa authorization exec default local
aaa session-id common
service-module wlan-ap 0 bootimage autonomous
crypto pki trustpoint TP-self-signed-XXXXXXXXX
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-XXXXXXXXX
revocation-check none
rsakeypair TP-self-signed-XXXXXXXXX
crypto pki certificate chain TP-self-signed-XXXXXXXXX
no ip source-route
ip dhcp excluded-address 192.168.20.1 192.168.20.10
ip dhcp pool Computers
import all
network 192.168.20.0 255.255.255.0
default-router 192.168.20.1
ip cef
no ipv6 cef
no spanning-tree vlan 2
no spanning-tree vlan 3
no spanning-tree vlan 4
vtp mode transparent
username admin privilege 15 secret 5 xxxxxxxxxxXXXXXXXXXXxxxXXxXxXXX
redundancy
controller VDSL 0
vlan 2-4
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface Ethernet0
no ip address
shutdown
interface GigabitEthernet0
description Switch
switchport trunk allowed vlan 1-4
switchport mode trunk
no ip address
interface GigabitEthernet1
description DMZ
switchport access vlan 2
switchport mode access
no ip address
interface GigabitEthernet2
description Open
switchport access vlan 3
no ip address
interface GigabitEthernet3
description Computers
switchport access vlan 4
no ip address
spanning-tree portfast
interface GigabitEthernet4
no ip address
interface GigabitEthernet5
no ip address
interface GigabitEthernet6
no ip address
interface GigabitEthernet7
no ip address
interface GigabitEthernet8
description WAN
ip address dhcp
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
no cdp enable
arp timeout 300
interface Wlan-GigabitEthernet8
no ip address
interface wlan-ap0
ip address 192.168.20.1 255.255.255.252
interface Vlan1
no ip address
interface Vlan2
description DMZ
ip address 192.168.10.1 255.255.255.0
ip nat inside
interface Vlan3
description Open
ip address 192.168.40.1 255.255.255.0
ip access-group OPEN-IN in
ip nat inside
interface Vlan4
ip address 192.168.20.1 255.255.255.0
ip access-group COMPUTERS-IN in
ip nat inside
no ip virtual-reassembly in
ip forward-protocol nd
no ip http server
ip http access-class 99
ip http secure-server
ip nat translation timeout 300
ip nat inside source static tcp 192.168.10.10 443 interface GigabitEthernet8 443
ip nat inside source list NAT interface GigabitEthernet8 overload
ip ssh version 2
ip access-list standard VTY
permit 192.168.40.0 0.0.0.255
ip access-list extended COMPUTERS-IN
permit icmp any host 192.168.20.1 echo
deny ip any 192.168.0.0 0.0.255.255
permit ip any any
ip access-list extended NAT
permit ip 192.168.10.0 0.0.0.255 any
permit ip 192.168.40.0 0.0.0.255 any
permit ip 192.168.20.0 0.0.0.255 any
ip access-list extended OPEN-IN
permit tcp any host 192.168.40.1 eq 22
permit tcp any host 192.168.40.1 eq 443
permit icmp any any
permit ip any any
logging facility local1
ipv6 ioam timestamp
snmp-server community not-public RO VTY
access-list 99 permit 192.168.40.0 0.0.0.255
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
stopbits 1
line vty 0 4
access-class VTY in
transport input ssh
line vty 5 189
access-class VTY in
transport input ssh
end
I am hopeful that this is an easy task for many of you router jockeys
Kind regards!
not sure why your answers were deleted. Either way, try the below:
--> does that mean connections initiated from anywhere on the outside ?
access-list 101 permit tcp any 192.168.20.0 0.0.0.255 eq 2400
ip nat pool VLAN_4 192.168.20.2 192.168.20.254 netmask 255.255.255.0 type match-host
ip nat outside source list 101 pool VLAN_4 add-route
--> same here: connections initiated from anywhere on the outside to the DMZ host ?
access-list 101 permit udp any 192.168.10.0 0.0.0.255 eq 1820
ip nat pool VLAN_2 192.168.10.2 192.168.10.254 netmask 255.255.255.0 type match-host
--> this is permitted by default, as both are in the same subnet. Do you want to EXCLUDE everything else except that host ?
ip access-list extended ALLOW_SNMP
permit tcp host 192.168.10.10 host 192.168.10.1 eq 161
permit tcp host 192.168.10.10 host 192.168.10.1 eq 162
permit udp host 192.168.10.10 host 192.168.10.1 eq 161
permit udp host 192.168.10.10 host 192.168.10.1 eq 162
vlan access-map VACL_SNMP 10
action forward
match ip address ALLOW_SNMP
vlan access-map VACL_SNMP 20
action drop
--> same question here
ip access-list extended ALLOW_SSH
permit tcp host 192.168.10.10 host 192.168.10.1 eq 22
permit udp host 192.168.10.10 host 192.168.10.1 eq 22
vlan access-map VACL_SSH 10
action forward
match ip address ALLOW_SSH
vlan access-map VACL_SSH 20
action drop
7 Replies 7
it is not really clear what you are trying to accomplish:
Thanks for you reply.
Correct. Anywhere on or from the interweb using TCP 2400 can get access to the Computers Vlan.
Correct. Anywhere on or from the interweb using UDP 1820 will get access but only to the host in the DMZ Vlan with the IP 192.168.10.10.
I just tried using SNMP from behind the host 192.168.10.10 (a firewall) in the DMZ Vlan, against the router 192.168.10.1 and it failed.
Currently, the only ones who have SNMP access permission are hosts in the Open Vlan. Checked that the firewall is not blocking SNMP traffic and that is not the case. Only that host and the Open Vlan may have access to the router itself using SNMP.
As with SNMP, this is blocked. Tried using putty form behind the host 192.168.10.10 (firewall) in the DMZ Vlan against the router 192.168.10.1 and the connection was refused. This would indicate that the router is refusing it and not the firewall in the DMZ.
Twice now my replies to your follow up have been deleted after a short time.
action forward
action drop
action forward
action drop
Thank you very much!
there is a mistake in what I sent you. You can only apply one access map to each Vlan, so you have to consolidate the access map. You also need to apply the filter. The entire configuration would look like below:
vlan access-map VACL_SNMP_SSH 10
action forward
vlan access-map VACL_SNMP_SSH 20
action forward
vlan access-map VACL_SNMP_SSH 30
action drop
--> vlan filter VACL_SNMP_SSH vlan-list 2
Veridizer
Thanks for your reply.
Correct. Anywhere on the outside, if it is using TCP 2400 then it can reach the Computers Vlan and nothing else.
Correct. Anywhere on the outside, if it is using UDP 1820 then it can reach the DMZ Vlan, specifically the 192.168.10.10 host, and nothing else.
I just tried reaching the router from a host behind 192.168.10.10 in the DMZ Vlan using SNMP but was not able to do so. 192.168.10.10 should be the only host that may communicate with the router.
Tried accessing the router from a host behind 192.168.10.10 in the DMZ Vlan but got a connection refused. As with SNMP access, this should be limited to 192.168.10.10.
192.168.10.10 is a firewall in the DMZ Vlan. I triple checked that it is not blocking any connection to the router.
