Showing results forĀ
Search instead forĀ
Did you mean:Ā
cisco 3945 isr
bluesea2010
Level 5
Level 5
If we add a WIC ,the throughput will increase or it needs any license
the 3945 is end-of-life/end-of-sale. I don't think there ever was something similiar to the performance/boost licenses you find for the ISR4K.
Either way, max throughput was something like 350Mbps for that device. You don't need a license (unless of course you are trying to encrypt).
balaji.bandi
You Need uplift  License for higher  level.
BB
@balaji.bandi
Out of curiosity, since I looked all over the place, which license is required for the 3945 ? I don't think you can even get one anymore, even if you wanted to, since the device is EoL/EoS.
Was that something similar to the licensing on the ISR4Ks ?
May be i have not given full clarity, What i was meant to suggest was - user need to uplift to new Model and highlevel License for the new the new requirement.
is this make sense ?
BB
