Cisco 1841 boot failure
Wolfgang Maier
Hi everybody,
we have a problem with a Cisco 1841 router while booting. The router is loading the image from the CF card but gets stucked at this point:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
This is the  IOS we´re using: c1841-advsecurityk9-mz.124-3j.bin
Any attempts booting another IOS failed also.
Is this a hardware failure? Any hints are highly appreciated. Thank you.
P.S. I´ve noticed there´s the same issue here: https://learningnetwork.cisco.com/message/143993?tstart=10
paolo bevilacqua
Try booting with "ignore config" bit set.
If that fails also, unit is defective and must be replaced.
