06-09-2011 08:34 AM - edited 03-04-2019 12:40 PM
Hello to all !
i have a problem with new hwic 4shdsl card . I have 1841 router .
The router doesnt regognize the HWIC card:
sh ver :
Interner_r#sh ver
Cisco IOS Software, 1841 Software (C1841-ADVIPSERVICESK9-M), Version 12.4(25b), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 12-Aug-09 10:49 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Interner_r uptime is 3 hours, 17 minutes
System image file is "flash:c1841-advipservicesk9-mz.124-25b.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Cisco 1841 (revision 7.0) with 115712K/15360K bytes of memory.
Processor board ID FTX1148W0FA
6 FastEthernet interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
31360K bytes of ATA CompactFlash (Read/Write)
sh diag:
WIC/HWIC Slot 1:
Unknown WAN daughter card
WIC module not supported/disabled in this slot
Hardware Revision : 1.0
Top Assy. Part Number : 800-27311-01
Board Revision : B0
Deviation Number : 0
Fab Version : 02
PCB Serial Number : FOC13311YA6
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Product (FRU) Number : HWIC-4SHDSL
Version Identifier : V01
CLEI Code : IPUIA04RAA
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 05 0F 41 01 00 C0 46 03 20 00 6A AF 01
0x10: 42 42 30 88 00 00 00 00 02 02 C1 8B 46 4F 43 31
0x20: 33 33 31 31 59 41 36 03 00 81 00 00 00 00 04 00
0x30: CB 8B 48 57 49 43 2D 34 53 48 44 53 4C 89 56 30
0x40: 31 20 D9 02 40 C1 C6 8A 49 50 55 49 41 30 34 52
0x50: 41 41 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
if the problen is wrong IOS ?
Need yours help
06-09-2011 08:42 AM
Yes, just update IOS.
06-09-2011 11:19 AM
but my version must support (follow cisco.com)
Version 12.4(25b) ?
06-09-2011 11:21 AM
Enter youe part number in cisco.com search, you will have a link to a data sheet that mentions the minimum IOS to support your hardware. Then to download it, you will need a valid support contract.
Please remember to rate useful posts clicking on the stars below.
06-09-2011 11:33 AM
part number of hwic yes ?
06-09-2011 11:58 AM
Certainly.
