Cisco 1841 mtu size on FastEthernet
Leifkaare
Hello
Im using a Cisco 1841 where FastEthernet0/0 is the customers LAN, and FastEhternet0/1 is the WAN uplink.
When im trying to set the wan uplink to mtu size 1524 i get the following error: % Interface FastEthernet0/1 does not support user settable mtu.
Is there any way i can get the FastEhternet interface to support higher mtu size than the deafult 1500 ?
a.alekseev
Level 7
Level 7
there is no way.
why do you want to increase mtu?
The customer needs higher mtu size to allow for logon to some of their server systems
something is wrong...
1500 is enough...
Alekseev is correct. Your customer has probably a misunderstanding bout the MTU concept in IP networking.
