Cisco 1841 nat hide behind each interface with its ip address
themichman
I have a Cisco 1841, coming from the 10.100.100.0 network, i would like to be natted for the 10.20.1.0 network as i was coming from the 10.20.1.1 interface and for the 10.50.1.0 network as i was coming from the 10.50.1.1
thank you
7 Replies 7
what do you want to NAT ? Please indicate source (inside) and destination (outside) of what you want to achieve...
10.100.100.1 is the inside (source)
10.20.1.1 is outside (destination is the 10.20.1.0 network)
10.50.1.1 is outside (destination is the 10.50.1.0 network)
Hello
Humm  it very possible but you sure you don't mean the other away around?
if you dont what is the size of the 10.100.100.0 network and do wish 1:1 translation between these two hosts and the your internal network?
Kind Regards
Paul
the 10.100.100.0 is only two host network,it just an interconnect from a firewall interface to the router,it represents an interface on a firewall device with other networks.
the other networks are client network we need to support, they used to be connected to the firewall as well, but we need the extra interface for expansion, so we decided  to take an old Cisco 1841 that was laying around for the purpose of routing, but we cannot touch the clients equipment , they expect to receive traffic from a specific ip address, thats why the NAT.
for example, when i need to access the 10.20.1.0 network, im coming from ,lets say 192.168.0.0 behind the 10.100.100.1 interface, the equipment on the 10.20.1.0 network is expecting traffic from the 10.20.1.1 interface (access list i suppose) but it will see the source address as 192.168.0.10 and not 10.20.1.1 and the same on the 10.50.1.0 network, thats way we need the NAT on the Cisco for both networks
Hello
now that is clear - how do wish this this to be done in terms of the translation-
Exmaple:
1:1 translation
192.168.0.10 - 10.20.0.1
192.168.0.11 - 10-50.0.1
or
dynamically  for certain protocol ports etc
192.168.0.0 tcp 80 - 10.20.0.1
192.168.0.0 udp 53 - 10.50.0.1
Kind Regards
Paul
similar to 1:1 but not exactly
for example if a random client on the 192.168.0.0 network want to access the 10.20.1.0 network
192.168.0.123 - > nat 10.20.1.1
and another client 192.168.0.222 want at the same time access the same network
192.168.0.222 -> nat 10.20.1.1
and also at the same time another client 192.168.0.96 want to access the 10.50.1.0 network
192.168.0.96 -> nat 10.50.1.1
Hello
You dont need to use the 10.100.100.0 subnet if you are using the 192.168.0.0 network that is unless you wish to?
Example:
1841 rtr
int fe0/0
ip nat inside
ip address 192.168.0.1 255.255.255.0
int vlan 2
ip address 10.20.1.1 255.255.255.0
ip nat outside
int vlan 3
p address 10.50.1.1 255.255.255.0
ip nat outside
access-list 10 permit 192.168.0.0 0.0.0.255
route-map vlan2 permit 10
match ip address 10
match interface vlan2
route-map vlan3 permit 10
match ip address 10
match interface vlan3
ip nat inside source route-map vlan2 interface vlan2
ip nat inside source route-map vlan3 interface vlan3
Kind Regards
Paul
