Error creating default route on 3750 POE : "Invalid next hop address"
isagarran
Catalyst 3750 series PoE-48
Cisco IOS Software, C3750 Software (C3750-IPBASEK9-M), Version 12.2(53)SE2, RELEASE SOFTWARE (fc3)
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE (fc1)
System image file is "flash:c3750-ipbasek9-mz.122-53.SE2/c3750-ipbasek9-mz.122-53.SE2.bin"
I'm trying to configure the router and I got a problem.
I've a firewall behind a freebox router(192.168.0.x/24). All devices have a gateway IP address set to 192.168.1.9 which is the IP address of the firewall.
I would like to define multiple VLANs on the CISCO switch behind.
Configuration targeted is :
Vlan Id     IP Network            Name                   Additional info              IP address
Vlan 2    192.168.1.0/24      Data-VLAN         Servers, Workstations   192.168.1.9
Vlan 3    192.168.3.0/24      Voice-Vlan          CUCM, IP Phones        192.168.3.9
Vlan 4    192.168.4.0/24      IP-cameras IP     Camera Network          192.168.4.9
Vlan 5    192.168.5.0/24      Mgmt-Wifi           WLC, Access Points    192.168.5.9
Vlan 6    192.168.6.0/24      Guest-VLAN        Guest Wifi VLAN          192.168.6.9
I defined each VLAN and IP address, I set the swich in routing mode. I checked using
show ip interface brief
Interface    IP-Address        OK?     Method    Status    Protocol
Vlan1        10.0.0.3           YES        other         up         up
Vlan2        192.168.1.9     YES        manual      up         down
Vlan3        192.168.3.9     YES        manual      up         down
Vlan4        192.168.4.9     YES       manual       up         down
Vlan5        192.168.5.9     YES       manual       up         down
Vlan6        192.168.6.9     YES       manual       up         down
FastEthernet 1/0/1 unassigned YES unset        down    down
I ran the command before setting the route
show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
10.0.0.0/24 is subnetted, 1 subnets
C     10.0.0.0      is directly connected,        Vlan1
Then finally I tried and failed to set the route
ip route 0.0.0.0 0.0.0.0 192.168.1.9
%Invalid next hop address (it's this router)
Could you help me and tell me where I'm wrong ?
Isagarran
14 Replies 14
The routes are not showing up in your routing table because the VLAN interfaces are down. Either way, the next hop for the default route needs to be an IP address NOT configured locally on the 3750.
Can you post the full config of the 3750 ? Do you have 'ip routing' enabled globally ?
Hello
Thanks for the reply. I think I did it globally.
I ran the "show running-config" command.
Regards.
Isagarran
ip routing is enabled, so that is fine.
Your VLAN interfaces are down because none of the ports are assigned to any of the VLANs. In order to see the VLAN routes in the routing table (show ip route) you need to assign them to ports, e.g.:
interface FastEthernet1/0/2
switchport mode access
switchport access vlan 2
spanning-tree portfast
interface FastEthernet1/0/3
switchport access vlan 3
interface FastEthernet1/0/4
switchport access vlan 4
interface FastEthernet1/0/5
switchport access vlan 5
interface FastEthernet1/0/6
switchport access vlan 6
Either way, as stated, you cannot use any of the local IP addresses as the next hop.
Well, the error is unavoidable (without using VRF) because the fact is the route is on that router.
When an IP address is on the device, the device already knows how to get there - it is in fact the destination. So, telling a router (ip route) to route certain traffic (0.0.0.0 0.0.0.0) to itself (in this case, 192.168.1.9) would be the same as saying, "Hey, if you don't know where to go, then go to yourself to find out where to go."
This is a loop.
So,w hat are you actually trying to overcome here? There is likely another solution.
Deepak Kumar
As I am getting your question, you are trying to configure default router on the Cisco Switch and as per configuration you have attached VLAN2  is also having the same IP on the switch:
interface Vlan2
 ip address 192.168.1.9 255.255.255.0
 So the switch will not allow to you.
In this case, your default route will be as
ip route 0.0.0.0 0.0.0.0 <firewall IP/Next hope IP Address>
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Thanks for all your replies. It helps me to clarify and better understand.
I attached the configuration ( as an image) I tend to have. I didn't represent the Freebox in front of that but it is. My CISCO Firewall has a LAN IP 192.168.1.9.
You were right, I did a mistake and VLAN 2 was wrong so I corrected it.
so now I have
Vlan2           192.168.2.9    YES manual   up      down
FastEthernet1/0/1 unassigned   YES unset    up      up
FastEthernet1/0/2 unassigned   YES unset    down    down
IP route command ran succesfully
Switch(config)#ip route 0.0.0.0 0.0.0.0 192.168.1.9
Switch(config)#end
But when i tried to see the route, I didn't see it. I ran the commands you gave me in order to assign all interfaces to the VLAN.
I didn't set "fastport" parameter to some interfaces I plan to connect to firewall or Wifi access devices.
I attached my last configuration.
Thanks for your help. I appreciated.
Isagarran
Hello
I forgot to add the show Ip route
show ip route
Here it is.
thanks
Isagarran
HI,
Becuase there is no subnet on your switch with 192.168.1.0/?
If you have Point to point l3 link then make one L3 interface make one more VLAN with the subnet.
Deepak Kumar
Deepak Kumar,
Hello
I created (in fact I changed VLAN 2 configuration) but now i'm lost. I've no clues on where's my problem.
configure terminal
Switch(config-if)#interface Vlan2
Switch(config-if)#ip address 192.168.1.254 255.255.255.0
Switch(config-if)#no shutdown
Switch(config-if)#end
I set the route and I checked if it exist. Alas it doesn't !
Switch(config)#end
Switch#show ip route
I checked my configuration is well done
Vlan2                  192.168.1.254   YES manual up                    down
GigabitEthernet1/0/3   unassigned      YES unset  down                  down
GigabitEthernet1/0/4   unassigned      YES unset  down                  down
Loopback1              unassigned      YES unset  up                    up
So it seems it is OK. but the route isn't.
I attach my last configuration.
If you have some ideas to share, let me know.
Regards.
Isagarran
--> Vlan2 192.168.1.254 YES manual up down
That is why you don't see the route. You need to assign a port to the Vlan, and connect something to that port so that it is up/up.
Hello
I lost the configuration. I recreated it but I did a wrong configuration (port defined to connect the firewall was wronly defined). The VLAN management 1 had 10.0.0.1 address and I didn't modify it. Now when I tried to enter in Express mode, the led blinks. As I understood, it is expected. But I'm no longer able to connect to the switch to reconfigure it.
I've to reinitialize it and reconfigure it correctly.
I think this "Invalid next hop address" subject can be closed.
Thanks for your help,
Isagarran
I am not sure what is your meaning with "Reconfigure". Has did factory reset to the switch?
Deepak Kumar
Deepak Kumar,
Yes . As I'm unable to join the switch in order to configure correct IP address, I'll have to reset the switch and configure all rules again.
I let one interface on VLAN 1 and I didn't modify the IP address.
interface FastEthernet1/0/1
interface Vlan1 ip address 10.0.0.1 255.255.255.0 secondary ip address 10.0.0.3 255.255.255.0
But since I ran the command "copy run start", the switch reboated (I didn't do the reload command)
then I do no longer able to connect on 10.0.0.1. So reset seems to be the only issue.
Isagarran
VLAN 2 protocol is showing down means it is not assigned to any interface or assigned interface is down.
Deepak Kumar
Deepak Kumar,
