Showing results forĀ
Search instead forĀ
Did you mean:Ā
Cisco 1841 or 1921 router operate with WIC-4ESW card
Hello everyone, I have two old routers 1841 and 1921 series with IOS 12.2(4) and 15.1 and I would like to install a WIC-4ESW card on slot 0/1 (?), is it possible (?) Or what limitations do I have? thanks
Seb Rupik
Hi there,
The card will not work in either platform. Both the 1841 and 1921 require HWIC cards.
cheers,
Seb.
BlackHornet
I think HWIC cards may be required.
Both 1841 and 1921 doesn't support the WIC-4ESW module: https://www.cisco.com/c/en/us/td/docs/routers/access/interfaces/ic/hardware/installation/guide/oview_ic.html#30111
Regards, LG
*** Please Rate All Helpful Responses ***
