Cisco 1841 Router Load Balancing with WIC 2T and Ethernet port
pankajmalik1988
Hi:
Can we do the load balancing with WIC - 1T card as ISP - 1 and Ethernet card as ISP - 2 and other ethernet card as my LAN Network.
WIC - 1T - connected to ISP
Ethernet card - Connected to Secondary ISP
Second Ethernet card - connected to LAN Connection.
I would like to have load-balancing & fail-over between this two connections.
regards
Pankaj
Richard Burts
Pankaj
You have not told us some things about what you are contracting with both ISP and that makes it difficult for us to give you good answers. If you are peering with 2 ISP and will run BGP with both then there is one set of solutions. If you are peering with 2 ISP and using static routes there is a different set of solutions. If you have some other relationship contracted with the ISP then there might be another solution. So please provide some clarification about your environment and the ISPs.
Rick
Rick
I'm a bit suspicious about this post.
Very Similar question here, only posted yesterday. https://supportforums.cisco.com/message/3960462#3960462
Original poster has only been a member since yesterday. Seems too much of a coincidence.
I did post a solution for this, however, got deleted by a user.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Also see the users other posts, there are duplicates here.
