Cisco 1841 Router throughput issue
vvujicevic
We have a Cisco 1841 Router at the edge of our company, we recently upgraded our WAN link from 6 Mbit/s to 15 Mbit/s leased line, the problem i have is that i only get arround 9-10  Mbit/s on the LAN side. When i connect directly to provider's media converter i get full 15. All the info i could get on the internet about this router's throughput says it should have  38. I have removed everything from the interface (VPN, ACL's) exept NAT offcourse, and it has some improvement, it gets up to 11-11,5...
Is that all this Router can do? If it is what model should we upgrade to?
Thank you
2 Accepted Solutions
I would replicate the throughput problem and see what the CPU usage is during the period where the throughput it maxed out... it's not clear whether the output you posted is during congestion or otherwise?
At any rate, if IP Input is the highest CPU culprit, see : http://www.cisco.com/c/en/us/support/docs/routers/7500-series-routers/41160-highcpu-ip-input.html
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
kellylevine
I had a lot of issues with this 1841 router though put speed I was natting a cable modem into our network which had a speed of 60 meg download speeds I was only getting 7-10meg with the statement in there. Turned out to be a command on my interfaces " no ip route-cache cef". I'm not sure if it is a default config have no idea how it got in there. Now my config just has IP CEF nothing on the interfaces.
https://learningnetwork.cisco.com/thread/21603
ip dhcp pool CLIENT
 import all
 network 10.10.10.0 255.25
 default-router 10.10
 dns-server 68.105
ip cef
ip name-server 68.1
ip name-server 68.
ip name-server 68.
no ipv6 cef
10 Replies 10
Aaron Harrison
What's your processor utilization currently? Show proc cpu?
Have you verified your interfaces are clear of errors?
It's possible that it's underspecced, even just NAT might take a good chunk out of the 38Mb max throughput...
Aaron
Interfaces dont have a relevant error numbers, 1077547231 packets input, 1081247 errors, 822 CRC before clearing counters for the first time. I think it should be >1% to consider faulty interface, and i have changed the cable already.
After i took off  VPN and ACL's it had arround 5% cpu utilization and no improvement on WAN speed.
So your CPU is pretty low which suggests the router isn't struggling, does it peak when you are running throughput tests?
Perhaps you have a duplex misconfig generating those errors, that would negatively affect throughput. What's your interface config?
Maybe post up your whole config for review.
Aaron
duplex and speed are both auto. Sh interface shows them at full duplex  - 100 Mbps.
interface FastEthernet0/0
description LAN
ip address 10.5.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1360
duplex auto
speed auto
interface FastEthernet0/1
description LL-WAN
ip address xxxx
ip nat outside
no ip route-cache
duplex auto
speed auto
crypto map kriptomap
Unfortunately i cant post full config. :S
This is current cpu util:
Eherc-Mo#sh processes cpu sorted
CPU utilization for five seconds: 16%/4%; one minute: 8%; five minutes: 13%
 PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
 119  1561265576   631764673       2471  9.59%  4.03%  7.81%   0 IP Input
 253   123362540   158292107        779  0.55%  0.47%  0.58%   0 Crypto PAS Proc
  95     5735268   885622940          6  0.55%  0.55%  0.56%   0 Ethernet Msec Ti
 130          84          56       1500  0.47%  0.06%  0.01% 194 Virtual Exec
 182     3049444   236333478         12  0.15%  0.18%  0.16%   0 PPP manager
 115     1687576   230576124          7  0.15%  0.13%  0.15%   0 IPAM Manager
 319     1990308   236333478          8  0.15%  0.11%  0.13%   0 PPP Events
  47     1009768     1724342        585  0.15%  0.01%  0.00%   0 Net Background
 263      295544    38067157          7  0.07%  0.01%  0.00%   0 Atheros LED Ctro
 138      262880    29740004          8  0.07%  0.01%  0.00%   0 SSS Feature Time
  29     2618040     7856037        333  0.07%  0.05%  0.04%   0 ARP Input
 239     1727164   236974957          7  0.07%  0.09%  0.08%   0 MMON MENG
  64      271144     7622694         35  0.07%  0.02%  0.00%   0 Per-Second Jobs
  14           0           1          0  0.00%  0.00%  0.00%   0 IPC Session Serv
  13        1464      126887         11  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
  16       59052     7424407          7  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  12       13388     1522214          8  0.00%  0.00%  0.00%   0 IPC Event Notifi
  15           0           1          0  0.00%  0.00%  0.00%   0 IPC Zone Manager
  11           0           1          0  0.00%  0.00%  0.00%   0 OIR Handler
  20        3232      435019          7  0.00%  0.00%  0.00%   0 IPC Check Queue
  21           0           1          0  0.00%  0.00%  0.00%   0 IPC Seat RX Cont
  22           0           1          0  0.00%  0.00%  0.00%   0 IPC Seat TX Cont
  17       54036     7424412          7  0.00%  0.00%  0.00%   0 IPC Deferred Por
  18           0           1          0  0.00%  0.00%  0.00%   0 IPC Process leve
  10           0           1          0  0.00%  0.00%  0.00%   0 License Client N
  26           0           1          0  0.00%  0.00%  0.00%   0 Crash writer
  27           0           1          0  0.00%  0.00%  0.00%   0 Exception contro
  19           0           1          0  0.00%  0.00%  0.00%   0 IPC Seat Manager
  23        5808      761348          7  0.00%  0.00%  0.00%   0 IPC Keep Alive M
  30      103320     7932300         13  0.00%  0.00%  0.00%   0 ARP Background
  31           0           2          0  0.00%  0.00%  0.00%   0 ATM Idle Timer
  32           0           1          0  0.00%  0.00%  0.00%   0 ATM ASYNC PROC
  33           0           1          0  0.00%  0.00%  0.00%   0 CEF MIB API
  34           0           1          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
  35           0           1          0  0.00%  0.00%  0.00%   0 Policy Manager
  36           0           2          0  0.00%  0.00%  0.00%   0 DDR Timers
  24       21908     1522316         14  0.00%  0.00%  0.00%   0 IPC Loadometer
  25        2944      253762         11  0.00%  0.00%  0.00%   0 Environmental mo
  39           0           2          0  0.00%  0.00%  0.00%   0 Serial Backgroun
  40           0           1          0  0.00%  0.00%  0.00%   0 RMI RM Notify Wa
Aaron
its production time now, so its never higher than ATM. here is 1 min ago:
sh proc cpu hist
 02:15:08 PM Wednesday Dec 17 2014 UTC
      2222444448888844444444446666644444111113333344444     666662
      111155555000005555500000999997777722222666669999988888222224
  100
   90
   80          *****
   70          *****          *****
   60          *****          *****                         *****
   50     ***************     **********          *****     *****
   40     ******************************     **********     *****
   30     ******************************     **********     *****
   20 **********************************     **********     ******
   10 ************************************************************
     0....5....1....1....2....2....3....3....4....4....5....5....6
               0    5    0    5    0    5    0    5    0    5    0
               CPU% per second (last 60 seconds)
      6663249543 1113494449425515374311222332234563597932211226752
      246061211392306011186303378354478666270036336650777786186801
  100                     *                         * *
   90       *         *   *                         * *
   80       *         *   *       *                 * *        *
   70   *   *         *   *       *                 ***       **
   60 ***   #         *   *     * *              * ****       **
   50 ***   #*        *  **  ** * *            *** ****       ***
   40 ***  *#**     ******#* ** * **       *   *********      *#*
   30 ###***#***    **#***#* #* *****  *****  ******#*****   *##*
   20 ###***#***    ########*#****###**#####***###*#####******###*
   10 ############################################################
               CPU% per minute (last 60 minutes)
              * = maximum CPU%   # = average CPU%
      999988993439234887796899997999993389332372294899899999999889989986232888
      797976502651529997984699879587969504486789193699996969898439549930512666
  100 ****  *            *  **** *****           *  ** ********  ** **
   90 ********   *   **  * ***** *****   *       * ************  ** **     ***
   80 ********   *   ***** ***********  **    *  * *****************#**    ***
   70 ********   *   *#*** ***********  **    *  * **********#########*    ***
   60 ********   *   *#***************  **    *  * **********#########**   ***
   50 ******** * *  *##***************  **    *  * *********##########**   ***
   40 ******** ***  *##******************* * **  ***********###########*   ***
   30 **#************###****#******************* ***#***#**############*** ***
   20 ####*##********###****####*####*********#*****###################*******
   10 ########***#***#########################################################
     0....5....1....1....2....2....3....3....4....4....5....5....6....6....7..
               0    5    0    5    0    5    0    5    0    5    0    5    0
                   CPU% per hour (last 72 hours)
sh proc cpu sor
CPU utilization for five seconds: 24%/6%; one minute: 35%; five minutes: 26%
 119  1561396868   631813753       2471 14.93% 22.94% 16.51%   0 IP Input
 253   123371280   158306059        779  1.11%  1.19%  0.99%   0 Crypto PAS Proc
   5    13480684     1299964      10370  1.03%  0.20%  0.17%   0 Check heaps
  95     5735652   885695035          6  0.47%  0.54%  0.55%   0 Ethernet Msec Ti
 182     3049712   236352887         12  0.23%  0.20%  0.18%   0 PPP manager
 319     1990472   236352887          8  0.15%  0.12%  0.13%   0 PPP Events
 314     1017728    14994008         67  0.07%  0.03%  0.02%   0 IP NAT Ager
 239     1727292   236994484          7  0.07%  0.08%  0.07%   0 MMON MENG
  29     2618360     7856983        333  0.07%  0.04%  0.05%   0 ARP Input
 130        1024         197       5197  0.07%  0.20%  0.16% 194 Virtual Exec
 115     1687708   230595170          7  0.07%  0.14%  0.15%   0 IPAM Manager
  12       13388     1522341          8  0.00%  0.00%  0.00%   0 IPC Event Notifi
  13        1464      126897         11  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
  16       59060     7425026          7  0.00%  0.00%  0.00%   0 IPC Periodic Tim
   9           0          78          0  0.00%  0.00%  0.00%   0 WATCH_AFS
  20        3232      435055          7  0.00%  0.00%  0.00%   0 IPC Check Queue
   8           0           2          0  0.00%  0.00%  0.00%   0 Timers
  17       54048     7425031          7  0.00%  0.00%  0.00%   0 IPC Deferred Por
  24       21908     1522443         14  0.00%  0.00%  0.00%   0 IPC Loadometer
  25        2944      253783         11  0.00%  0.00%  0.00%   0 Environmental mo
  28       22088      319294         69  0.00%  0.00%  0.00%   0 CRYPTO IKMP IPC
  30      103324     7932961         13  0.00%  0.00%  0.00%   0 ARP Background
  23        5808      761412          7  0.00%  0.00%  0.00%   0 IPC Keep Alive M
  41           0           2          0  0.00%  0.00%  0.00%   0 SMART
  42       65016     7614055          8  0.00%  0.00%  0.00%   0 GraphIt
  43           0           2          0  0.00%  0.00%  0.00%   0 Dialer event
  44           0           1          0  0.00%  0.00%  0.00%   0 SERIAL A'detect
So usage is peaking regularly - I'd verify the IP INput related stuff in the doc I posted earlier. You can try to reduce the utilisation by looking at the steps there... perhaps even doing a pcap on the inside and outside interfaces do see if there are lots of broadcasts or other types of traffic that might bump it up.
Otherwise you could look at a higher spec router.
The info is all in that doc..
Aaron
Turns out CEF was disabled for some reason... Im blind for not seeing it in first place. Thanks for your help
Glad I could help I was about to remove that router an blame it on slow CPU sure works good now.
kellylevine
ip dhcp pool CLIENT
 import all
 dns-server 68.105
ip cef
ip name-server 68.1
ip name-server 68.
ip name-server 68.
no ipv6 cef
