Cisco 1841 two dsl modems two NIC's
lance_506E
I have a 1841 with WIC 4 Port FE Swtich added. I have two standard ports set for Outside Public IP address, the FE Switch set to two Vlans one at 192.168.0.1 and the other 192.168.1.1, but I can't get both modems to work at the same time.
My question is how to get both modems to work and have some computers defualt gateway to which ever modem I want for that workstation. I don't have to have two subnets necessarally this is just the way I thought it should be. I perfer one subnet if possible.
My reason for this is my server have dual NIC's and I want to be able to back them up over the internet on a different modem than the workstations for user internet access. So I don't bog down the bandwith.
I new to Cisco and routers.
Lance
paolo bevilacqua
That is called policy routing, which you can search.
Note, is not a task for the beginner.
