Cisco 1841 won't connect to the ADSL
espoke2008
Dear Cisco Experts,
This is the first time I have posted here, so please be easy on me.
I am having a real problem with a Cisco 1841 Router. It is driving me mad!
Everything works except it won't connect to our ADSL ISP. The OK light on the WIC card is on and the CD light initially flashes and then goes off. I am 99.9% sure that the username and password are correct.
I have attached the config incase there is anything really obvious that I am missing.
Your help would be REALLY appreciated.
Many many thanks!
Peter
paolo bevilacqua
Do you have an hwic-1adsl ? If so try upgrading firmware:
ftp.cisco.com/pub/access/800
with a doc for installation
the one you want 3.0.13. others don't apply.
