Cisco 1941 Configuration Help
swdowsett
Hello everyone,
I am new to posting to the Cisco Support Community, though I read tips on here regularly because it is quite helpful to understanding common issues with Cisco products. Anyway I am in need of help and am wondering if you guys could help me out, it would be greatly appreciated!
So I am having issues with a clients 1941 router, I did the initital configuration on it and someone else did the rest, though now it will not connect to the internet, more specifically it will not do any NAT translations, will not ping public internet addresses (or allow them to be resolved though that might be from our ACL). Anyways, I have tried a basic configuration to try to eliminate the current one as a potential issue, no dice so far. Oddly enough I can reach it and manage it from its public interface/ip remotely just no traffic can pass through it. In preventing this from being TL;DR here is the current config, for security reasons I omitted certain things and lets say my public ip is 10.0.0.1 for this purpose.
If you could help me out it would be great because I might be overlooking something here.
Config:
version 15.1
service password-encryption
hostname WIN_GW
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
no ipv6 cef
no ip source-route
ip cef
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip inspect name FIREWALL tcp
ip inspect name FIREWALL udp
ip inspect name FIREWALL icmp
ip inspect name FIREWALL_IN pptp
ip inspect name FIREWALL_IN ipsec-msft
login block-for 30 attempts 4 within 15
login delay 5
crypto pki trustpoint TP-self-signed-1997974926
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1997974926
revocation-check none
rsakeypair TP-self-signed-1997974926
crypto pki certificate chain TP-self-signed-1997974926
certificate self-signed 01
<output omitted>
            quit
license udi pid CISCO1941/K9 sn FTX1613804K
username <omitted> privilege 15 secret 5 <omitted>
redundancy
no ip ftp passive
ip ssh version 2
interface Loopback0
no ip address
shutdown
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description ###CONNECTION TO INTERNET###$FW_OUTSIDE$
ip address 10.0.0.1 255.255.255.0
ip access-group OUTSIDE_IN in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip inspect FIREWALL_IN in
ip inspect FIREWALL out
ip virtual-reassembly in
duplex auto
speed auto
no cdp enable
interface GigabitEthernet0/1
description ### INTERNAL LAN ###$FW_INSIDE$
ip address 172.1.0.8 255.255.0.0
ip nat inside
duplex auto
speed auto
no cdp enable
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source route-map NAT interface GigabitEthernet0/0 overload
ip nat inside source static tcp 172.1.0.6 25 10.0.0.1 25 extendable
ip nat inside source static tcp 172.1.0.41 443 10.0.0.1 443 extendable
ip nat inside source static tcp 172.1.0.41 465 10.0.0.1 465 extendable
ip nat inside source static tcp 172.1.0.36 1723 10.0.0.1 1723 extendable
ip nat inside source static tcp 172.1.0.36 2080 10.0.0.1 2080 extendable
ip nat inside source static tcp 172.1.0.41 3389 10.0.0.1 45000 extendable
ip nat inside source static tcp 172.1.0.20 3389 10.0.0.1 45001 extendable
ip nat inside source static tcp 172.1.0.58 3389 10.0.0.1 45002 extendable
ip route 0.0.0.0 0.0.0.0 10.0.0.2
ip route 192.168.20.0 255.255.255.0 172.1.0.3
ip route 192.168.35.0 255.255.255.0 172.1.0.3
ip route 192.168.36.0 255.255.255.0 172.1.0.3
ip route 192.168.40.0 255.255.255.0 172.1.0.3
ip access-list extended NAT
deny   ip 172.1.0.0 0.0.255.255 10.0.0.0 0.255.255.255
deny   ip 172.1.0.0 0.0.255.255 172.16.0.0 0.15.255.255
deny   ip 172.1.0.0 0.0.255.255 192.168.0.0 0.0.255.255
deny   ip 192.168.20.0 0.0.0.255 10.0.0.0 0.255.255.255
deny   ip 192.168.20.0 0.0.0.255 172.16.0.0 0.15.255.255
deny   ip 192.168.20.0 0.0.0.255 192.168.0.0 0.0.255.255
deny   ip 192.168.35.0 0.0.0.255 10.0.0.0 0.255.255.255
deny   ip 192.168.35.0 0.0.0.255 172.16.0.0 0.15.255.255
deny   ip 192.168.35.0 0.0.0.255 192.168.0.0 0.0.255.255
deny   ip 192.168.36.0 0.0.0.255 10.0.0.0 0.255.255.255
deny   ip 192.168.36.0 0.0.0.255 172.16.0.0 0.15.255.255
deny   ip 192.168.36.0 0.0.0.255 192.168.0.0 0.0.255.255
deny   ip 192.168.40.0 0.0.0.255 10.0.0.0 0.255.255.255
deny   ip 192.168.40.0 0.0.0.255 172.16.0.0 0.15.255.255
deny   ip 192.168.40.0 0.0.0.255 192.168.0.0 0.0.255.255
permit ip 172.1.0.0 0.0.0.255 any
permit ip 192.168.20.0 0.0.0.255 any
permit ip 192.168.35.0 0.0.0.255 any
permit ip 192.168.36.0 0.0.0.255 any
permit ip 192.168.40.0 0.0.0.255 any
ip access-list extended OUTSIDE_IN
permit udp host 64.90.182.55 eq ntp host 10.0.0.1 eq ntp
permit udp host 24.56.178.140 eq ntp host 10.0.0.1 eq ntp
permit udp host 129.6.15.29 eq ntp host 10.0.0.1 eq ntp
permit udp host 129.6.15.28 eq ntp host 10.0.0.1 eq ntp
permit tcp any host 10.0.0.1 eq telnet
permit tcp any host 10.0.0.1 eq 22
permit tcp any host 10.0.0.1 eq smtp
permit tcp any host 10.0.0.1 eq 8013
permit tcp any host 10.0.0.1 eq 443
permit tcp any host 10.0.0.1 eq 45002
permit tcp any host 10.0.0.1 eq 45001
permit tcp any host 10.0.0.1 eq 45000
permit tcp any host 10.0.0.1 eq 2080
permit tcp any host 10.0.0.1 eq 465
permit tcp any host 10.0.0.1 eq 1723
permit gre any host 10.0.0.1
permit esp any host 10.0.0.1
permit udp any host 10.0.0.1 eq isakmp
route-map NAT permit 10
match ip address NAT
control-plane
line con 0
exec-timeout 30 0
logging synchronous
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
exec-timeout 15 0
privilege level 15
logging synchronous
login local
transport input telnet ssh
scheduler allocate 20000 1000
ntp update-calendar
ntp server 24.56.178.140 source GigabitEthernet0/0
ntp server 64.90.182.55 prefer source GigabitEthernet0/0
end
EDIT:
I am wondering if it is the environment, the current firewall/gateway is a linux solution and has no issue contacting our ISP default gateway or getting the users to the internet. The idea was for the Cisco device to replace it because it was a repurposed server that is getting old.
My concerns is the cisco 1941 is defective, but it functions fine when pointed to other firewall (which is to be removed), this lead me to believe it has something to do with the NAT translations...
Thanks in advance for your input!!!!
Message was edited by: Scott Dowsett
19 Replies 19
with the previous config you used for posting the debugs, can you do a sh  ip inspect session detail while pinging 8.8.8.8
from the router with a repeat count of 1( ping 8.8.8.8 rep 1)
Regards.
Alain
Hello Alain,
I would like to thank you for sticking with me through this and giving suggestions to helping me out!
I figured it out after Jonathan posted his suggestion.
I really appreciate your help in this matter, I will definetly take away better troubleshooting from your suggestions!
Again Thanks to everyone who helped me out
This community rocks!
swdowsett
Hey guys,
So now my router config is working, but as soon as I enable my OUTSIDE_IN acl to my public interface in the in direction, I lose internet connection and nothing can get through. Is there any reason for this? To my understanding extended access lists go closest to source of packets. It is only in the in direction so will I need to make "established" arguements? I understand there is an implicit deny at the end of all acls however no matter what I do to tweak it just keeps blocking me off entirely.
I do understand ACL concepts but they are not my strong point. Any suggestions?
Thanks so much for your help in advance!!!
You mention "established" arguments. I can tell you that the "ip inspect" commands essentially do the same thing. "Established" is just the old way of doing it (and only possible for TCP), whereas ip inspect covers UDP/TCP/ICMP/etc. Short answer... this is a red herring. Stick with ip inspect.
Alain is correct. You should be able to run the command "sh ip inspect session" and it should show the connections that the inspect firewall knows about (and is therefore allowing through the OUTSIDE_IN firewall). Just make sure you generate some traffic beforehand (even if it fails).
To quote you:
Defining how you confirmed internet connectivity loss is important. Did you run a ping from the router to the internet? Did you ping from remote to the site's public IP? Did you get a user onsite to ping something? Did you try something other than ping (i.e. PPTP/SSH/TELNET/etc)
There is a few ways you could go about this. In my mind I'd prefer to see "ip inspect FIREWALL in" on Gig0/1 rather then Gig0/0. This essentially says "as connections come in on my LAN interface, build a session entry for them and remember to bypass on the way back". Having "ip inspect FIREWALL out" on Gig0/0 says "as connections out of the Internet interface, build a session entry for them and remember to bypass through any firewalls". Since you have OUTSIDE_IN ACL and another ip inspect FIREWALL_IN applied to the same interface... I start to get a bit confused.
Here's what I would do first:
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
no ip inspect FIREWALL_IN in
no ip inspect FIREWALL out
duplex auto
speed auto
no cdp enable
ip nat inside
duplex auto
speed auto
no cdp enable
With ACLs they are processed from top to bottom. What you could do it try add a few lines to the ACL to see whether they are indeed being dropped by the ACL. Don't forget you can run the "show ip access-list OUTSIDE_IN" command to see the number of "hits" on a particular ACL entry.
Good luck.
Thanks for the reply Jonathan.
I did not configure the ACL or the FIREWALL statements on the interface (that was the other persons responsibility, I kind of inherited this when things didn't function), My comfort in knowledge level is stretched a bit thin in that area. However, in reading your suggestions and how you explained it makes more sense to me, I will correct and see where it takes me, I think I have a pretty good handle on what I need to do to get that functioning. I really appreciate your help on this!
All the best!
Scott
