Cisco 1941 - no ip inspect?
louis0001
Level 3
Level 3
Hi, anyone got any idea why there is no ip inspect command on a Cisco 1941?
Version is 15.1 (M4) and ipbasek9
I can use a reflexive list but wanted to use CBAC but the ip inspect command isn't present.
Hello
CBAC is supported but you need to upgrade the IOS to Universal feature set
Kind Regards
Paul
5 Replies 5
It's probably because your license does not support it - you would need the Security license in order to configure the firewall.
Regardless you should consider Zone Based Firewall (ZBFW) instead, reference here - this would also require the security license.
You should also consider upgrading the IOS if possible, the latest is 15.7.
Hello
Kind Regards
Paul
Hi, is the below not a universal feature set?
c1900-universalk9-mz.SPA.151-4.M4.bin
your IOS image should support right to use activation. Check if you can execute the below:
1. license right-to-use activate ipservices | lanbase} {all | evaluation all } [slot slot-number] [
acceptEULA]
2. reload [ LINE | at |
Brill. That was it. Thank you.
