Cisco 1941 not saving running config
kwjorders
Hello I working on setting up a new Cisco 1941 router I just bought and it is not saving my config  when I run copy run start and write memory.  I checked the startup config after running the command and it saves my changes but when I reboot the router it clears all my changes.  I noticed these lines when starting up which I though could be the cause
Upgrade  rommon initialized
%SYS-6 Startup_Config_Ignored
-Thanks
config-register-2102-vs2142.jpgDo you change register set ?
I did not myself, just turned in on and logged in with my console cable.  I bought it used though.
-Thanks
Did not see that image to just now, that was the issue it is fixed now.
-Thanks
You Are So So Welcome
