Cisco 1941 Router - WAN
svenkasier
As I am looking days already to find a good guide or manual... I cannot find how to install a WAN port on int g0/0..
Everything I try is not working. From things I've read I tried also not working sadly.
Is there anyone who has a good manual/tutorial on this?
Or can guide me through in a small step per step guide.
Kind Regards,
Sven
2 Accepted Solutions
Can you post what you've done and what you're seeing happen? Technically, the only thing you would need for dhcp is:
int g0/0
ip address dhcp
HTH,
John
HTH, John *** Please rate all useful posts ***
Yes it does...
At the # prompt
router# config t <enter>
9 Replies 9
John Blakley
Can you tell us a little more about the connection type that you're using? Is it an ethernet circuit, DSL, cable, etc?
My setup is:
Modem(DHCP included) to Cisco 1941
int g0/0
ip address dhcp
HTH,
John
Hello John,
This works.. But I still don't have any internet connection. Limited acces:
version 15.2
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
license udi pid CISCO1941/K9 sn FCZ18139130
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 ip address dhcp
 duplex auto
 speed auto
interface GigabitEthernet0/1
 ip address 20.30.40.1 255.255.255.0
 duplex auto
 speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 login
 transport input all
scheduler allocate 20000 1000
end
I configured my pc in the range of 20.30.40.50
                                                      255.255.255.0
                                                       20.30.40.1
You'll need to configure nat as well. For example:
access-list 100 permit ip 20.30.40.0 0.0.0.255 any
ip nat inside source list 100 interface g0/0 overload
You'll also need to specify a default route:
ip route 0.0.0.0 0.0.0.0 <whatever the gateway is that your ISP gave you>
You may already have a default route from DHCP. To check, do "show ip route 0.0.0.0" If you get something back, it should tell you what your next hop is. Or you can just do "show ip route" and look for the line that says "Last resort". That's your ISPs router....
Sorry for being an amateur. But this commands just go into the conf t modus?
Thanks in advance!
Yes it does...
At the # prompt
Working like a charm now, thanks :)
You're welcome! I'm glad to hear it :)
