Cisco 1941 Router
spaseman.spiff
I am new to the Network arena. My company purchased a Cisco 1941, and I need to configure it for one of our offices.
I have researched and done the basics, but now need assistance witht the rest of my configuration.
I have been given the following information:
216.7.133.242 - Your static IP
216.7.133.241 - the Gateway
255.255.255.252 - Subnet Mask
64.191.128.10 and 64.191.128.101 - DNS servers
Here's is my basic config info so far:
interface GigabitEthernet0/0
descrption router
ip address 216.7.133.242 255.255.255.252
duplex auto
speed auto
I still need to configure the gateway address, and the DNS entries.
Apologies for my ignorance.. :O)
Thank you!!
- Joey
edondurguti
Level 4
Level 4
enter the clobal config from enable mode
conf t
ip route 0.0.0.0 0.0.0.0 216.7.133.241
ip name-server 64.191.128.10 64.191.128.101
end
wr
7 Replies 7
edondurguti
Level 4
Level 4
conf t
end
wr
Edon -
Thanks soooo much for the the assistance on this !!!
- Joey
No problem.
Please mark as correct answer, thank you
johnlloyd_13
Level 9
Level 9
hi joey,
further adding to edon's post, you should also configure the LAN interface and consider if the DHCP and NAT will be performed by this router.
int g0/1
ip address 192.168.1.254 255.255.255.0
ip nat in
int g0/0
ip nat out
access-list 1 permit 192.168.1.0 0.0.0.255
ip nat inside source list 1 interface g0/0 overload
ip dchp pool LAN
network 192.168.1.0 255.255.255.0
default-router 192.168.1.254
dns-server 8.8.8.8
John -
Thanks for the assistance. You lost me with the 192.x.x.x address. I take it I replace the 192.x.x.x address with my IP_address?
Thanks.
- Joey
hi joey,
the suggested 192.x.x.x is the private IP range for your LAN. that is, if you plan to use one though.
D'oh !!!  Thanks.
