Cisco 1941 SecurityK9 License
Thomas Cotton
I have a Cisco 1941 with the SecurityK9 license applied however I cannot run the 'interface Virtual-PPP' and 'pseudowire-class' commands which I have seen within other examples on Cisco VPN config. Should my router have these commands? As you can see the securityk9 license is applied and permanent.
Technology Package License Information for Module:'c1900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security securityk9 Permanent securityk9
data None None None
I'm after connecting this router to the Private Internet Access (PIA) VPN server in a site to site configuration.
Cheers
I checked the Feature Navigator: you need the DATA feature set/license (which you don't have) in order to run Any Transport over MPLS (pseudowire-class) commands.
which IOS version are you running ? The below version is an example is one that contains the 'pseudowire-class' command:
IOS: c1900-universalk9-mz.SPA.152-4.M2.bin
Almost exactly the same:
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.2(4)M3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Tue 26-Feb-13 02:11 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M15, RELEASE SOFTWARE (fc1)
Cotton_1941 uptime is 1 day, 2 hours, 51 minutes
System returned to ROM by reload at 17:18:58 UTC Sun Nov 27 2016
System restarted at 17:20:39 UTC Sun Nov 27 2016
System image file is "flash0:c1900-universalk9-mz.SPA.152-4.M3.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
Cisco CISCO1941/K9 (revision 1.0) with 491520K/32768K bytes of memory.
Processor board ID *********
2 Gigabit Ethernet interfaces
1 terminal line
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity disabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*0 CISCO1941/K9 *******
data None None None
Thanks!! Enabled data license and working
