Leaking Routes between VRFs
GRANT3779
Hi All,
If I have VRF1 running OSPF and VRF2 running EIRGP, can I leak routes between each VRF or are they required to have the same routing protocol running?
Separately - When leaking between VRFs, does this affect the AD of routes or is this kept the same?
Yes, its a little different when you going between global and a vrf.
Here are a couple links for more info:
http://www.cisco.com/c/en/us/support/docs/ip/ip-routing/200158-Configure-Route-Leaking-between-Global-a.html
https://mellowd.co.uk/ccie/?p=3645
Reza Sharifi
Yes, you can run different protocols for different VRFs. If you want the VRFs to communicate with each other than you would need to redistribute the VRF instances. The AD will change once you redistribute between VRFs.
Been doing further reading on this. If i want to leak routes between a VRF and the GRT, is the process different than it is from trying to leak routes between two separate VRFs?
Thanks Reza, I did have look over that Cisco Doc. I will look over other link you provided too.
