06-29-2021 07:25 AM
I configured IPSec on Cisco 1941 (c1900-universalk9-mz.SPA.157-3.M8.bin).
- I can connect via IPSEC
- I can ping from the IPSEC-client to the router and servers with the 192.168.0.x IP address behind Cisco 1941 router
- I can not do SSH to any 192.168.0.x prefixes.
Do you have any comment?
version 15.7
hostname rtr0
boot-start-marker
boot system flash0 c1900-universalk9-mz.SPA.157-3.M8.bin
boot-end-marker
aaa new-model
aaa authentication login AUTHC local
aaa authentication login a-eap-authen-local local
aaa authorization exec AUTHZ local
aaa authorization network a-eap-author-grp local
aaa session-id common
clock timezone GMT 1 0
ip domain name spr.co.uk
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip cef
no ipv6 cef
crypto pki trustpoint r0.spr.co.uk
enrollment pkcs12
revocation-check crl
rsakeypair r0.spr.co.uk
crypto pki certificate chain r0.spr.co.uk
certificate ca 3D907A9E2D30122428EAB821BB6F957AF1B7AD7E
30820313 308201FB A0030201 0202143D 907A9E2D 30122428 EAB821BB 6F957AF1
B7AD7E30 0D06092A 864886F7 0D01010B 05003019 31173015 06035504 030C0E53
656C6653 69676E65 64436572 74301E17 0D323130 36323832 31333635 325A170D
33323036 31303231 33363532 5A301931 17301506 03550403 0C0E5365 6C665369
676E6564 43657274 30820122 300D0609 2A864886 F70D0101 01050003 82010F00
3082010A 02820101 00C05A70 35643F06 A33690F8 3B61A5B2 826DD7ED EE8731E7
63321B42 14222BA7 86D14C2E A06F3ACD 0921FAA3 1F056B2C F56A72CF 970F5B14
769D8321 7F89C0C0 6242B3A2 D80F12FD FD9EAE12 E5480EAA FEC15CD9 70252B65
A3D2D5A1 18A737C1 B4FB2351 82C48A1F 18E41E12 97BAC568 78FF133A 0BDA3068
508AE903 A0014237 4C5C7F6B C6EBE1BD C6C57859 F786598F 8FF47ECF 5D23D409
3301F40E 25A05C5B 25E42CE5 B4CB0C71 766A3745 6D6A26D1 22BC3E1A ADBF6851
C0F25DC2 70C2B347 3621A93C DCC3D9D5 8FE5C249 C8CF4D9A 33931F4A CD0EBB64
0E0D491F EF9D50CA 3D73583A 877D3521 FB4EE146 11370507 2C635474 373011EF
47F39A4D 649A00E3 5B020301 0001A353 3051301D 0603551D 0E041604 14CAF668
A3D678BE DFA39790 18A53F4C E95D7FC2 C6301F06 03551D23 04183016 8014CAF6
68A3D678 BEDFA397 9018A53F 4CE95D7F C2C6300F 0603551D 130101FF 04053003
0101FF30 0D06092A 864886F7 0D01010B 05000382 01010064 83968BDD D7038304
2E7B49D7 504B5D2C 356DDD61 75F8CC6E CCCA046D C7A959E1 85C3C1BD 299760DD
47FEE16C 3D12B873 78E9FA21 45377632 32729595 7AAC0623 0CD93182 05B48B23
9C1EA5B3 B5346986 CE9262BA 4C5685D7 CF681060 4C75FA39 FEBBAE11 7C7B0432
00AD142E 7B3FDB48 3D8255B0 6BD357FF B54DB824 261FD492 E7F8418E 5BBEACE7
764946E5 2A315EBE AD082227 B07D9D3F 4804D1EB 23C2933C 9357B0B8 66FBCE20
F40E1D69 AD4F733A AE3DB282 8A05116D 2A85ABC1 C28FB5A5 89F2A747 FF0288C2
83571960 D22E5E61 B9174B72 1E576E91 1ED67321 091F5782 089C16D4 1CB5895A
577EA47A AFC0921A A0C434CA 072AA26C 4DB06745 D92804
quit
license udi pid CISCO1941/K9 sn FGL160925J6
license boot module c1900 technology-package datak9 disable
username frd privilege 15 secret 5 $1$7eP1$nB3tGyntxtHHU2wc7fZtE1
redundancy
crypto ikev2 authorization policy ikev2-auth-policy
pool IPSECPOOL
netmask 255.255.255.0
route set access-list split_tunnel
crypto ikev2 proposal IKEv2-prop1
encryption aes-cbc-256
integrity sha512
group 21 20 19 16 15 14
crypto ikev2 policy IKEv2-pol
crypto ikev2 profile AnyConnect-EAP
match identity remote key-id *$AnyConnectClient$*
authentication local rsa-sig
authentication remote anyconnect-eap aggregate
aaa authentication anyconnect-eap a-eap-authen-local
aaa authorization group anyconnect-eap list a-eap-author-grp ikev2-auth-policy
aaa authorization user anyconnect-eap cached
virtual-template 100
no crypto ikev2 http-url cert
crypto vpn anyconnect profile acvpn flash:/ACVPN.XML
crypto ipsec transform-set esp-gcm-256 esp-gcm 256
mode tunnel
crypto ipsec profile AnyConnect-EAP
set transform-set esp-gcm-256
set ikev2-profile AnyConnect-EAP
interface Loopback0
ip address 192.168.50.160 255.255.255.255
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.1
encapsulation dot1Q 1 native
ip address 192.168.0.160 255.255.255.0
ip virtual-reassembly in
interface Virtual-Template100 type tunnel
ip unnumbered GigabitEthernet0/0.1
ip mtu 1400
tunnel mode ipsec ipv4
tunnel protection ipsec profile AnyConnect-EAP
ip local pool IPSECPOOL 192.168.0.240 192.168.0.249
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.0.1
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh source-interface GigabitEthernet0/0.1
ip ssh logging events
ip access-list standard split_tunnel
permit 192.168.0.0 0.0.0.255
control-plane
line con 0
privilege level 15
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
exec-timeout 60 0
login authentication AUTHC
transport input all
scheduler allocate 20000 1000
ntp server 2.uk.pool.ntp.org
ntp server 0.uk.pool.ntp.org
ntp server 3.uk.pool.ntp.org
end
06-29-2021 07:41 AM
You getting the VPN Pool address from 192.168.0.X range right ?
can you show any small diagram how these device connected. i do not belive this is directlly expose to internet ? did this deivce ?
06-29-2021 08:20 AM - edited 06-29-2021 08:22 AM
I did port forwarding on internet router, and the anyconnect ipsec is terminating on this 1941.
Below is the output when the IPSEC is established
rtr0#sh crypto
Number of Crypto Socket connections 1
Vi2 Peers (local/remote): 192.168.0.160/109.249.187.60
Local Ident (addr/mask/port/prot): (0.0.0.0/0.0.0.0/0/0)
Remote Ident (addr/mask/port/prot): (192.168.0.244/255.255.255.255/0/0)
IPSec Profile: "AnyConnect-EAP"
Socket State: Open
Client: "TUNNEL SEC" (Client State: Active)
Crypto Sockets in Listen state:
Client: "TUNNEL SEC" Profile: "AnyConnect-EAP" Map-name: "Virtual-Template100-head-0"
Client: "TUNNEL SEC" Profile: "AnyConnect-EAP" Map-name: "Virtual-Access2-head-0"
rtr0#
This is the routing table on 1941
- I can ping to the IPSEC Client.
- I can also ping from IPSEC client (192.168.0.244) to the IP addresses on/behind 1941 (192.168.0.160, 192.168.0.152).
- I can ping from the server behind 1941 (192.168.0.152) to IPSEC client (192.168.0.244)
- But SSH doesnt work.
rtr0#sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is 192.168.0.1 to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 192.168.0.1
192.168.0.0/24 is variably subnetted, 3 subnets, 2 masks
C 192.168.0.0/24 is directly connected, GigabitEthernet0/0.1
L 192.168.0.160/32 is directly connected, GigabitEthernet0/0.1
S 192.168.0.244/32 is directly connected, Virtual-Access2
192.168.50.0/32 is subnetted, 1 subnets
C 192.168.50.160 is directly connected, Loopback0
192.168.200.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.200.0/24 is directly connected, GigabitEthernet0/0.200
L 192.168.200.1/32 is directly connected, GigabitEthernet0/0.200
192.168.201.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.201.0/24 is directly connected, GigabitEthernet0/0.1201
L 192.168.201.1/32 is directly connected, GigabitEthernet0/0.1201
rtr0#
07-03-2021 08:06 AM
Is it possible you are having MTU issues when you SSH? You could try a couple things like using Putty or some other telnet client and telnet to port 22 and see if you get the initial SSH herald. You could also run wireshark or some other packet capture tool to see what happens when you initiate the SSH connection.
